    Fix Windows 10 Update Issues
HP Officejet Pro 8000 Enterprise Printer Series - Set link speed
You can change the speed at which data is transmitted over the network. The default is Automatic.
  1. Press right arrow , and then select Configure Device.
  2. Select I/O Option, then select Link Speed.
  3. Press right arrow to scroll the different link speed and press OK for selection of the speed that matches your network hardware:
    • Automatic
    • 10-Full
    • 10-Half
    • 100-Full
    • 100-Half
