HP Officejet Pro 8000 Enterprise Printer Series - Printer specifications
Physical specifications
Size (width x height x depth)
  • Printer with duplexer: 494 x 180 x 479 mm (19.5 x 7.1 x 18.9 inches)
  • With Tray 2: Adds 66 mm (2.6 inches) to the height of the printer
Printer weight (does not include printing supplies)
  • Printer with duplexer: With Tray 2: 7.8 kg (17.2 lb)
  • With Tray 2: Adds 2.6 kg (5.7 lb)
Product features and capacities
Feature
Capacity
Connectivity
  • USB 2.0-compliant high speed
  • Wired network
Print method
Drop-on-demand thermal inkjet printing
Ink cartridges
Four ink cartridges (one each for black, cyan, magenta, and yellow)
NOTE: Not all ink cartridges are supported in all countries/regions.
Printheads
Two printheads (one black and yellow, and one magenta and cyan)
Supply yields
Visit www.hp.com/go/learnaboutsupplies/ for more information on estimated ink cartridge yields.
Printer languages
HP PCL 5e, PCL 6, PostScript® 3™ emulation
Font support
HP 80 Fonts (includes 45 scalable True Type fonts, 35 build-in PostScript language fonts and one bit-mapped line printer font).
Duty cycle
Up to 15,000 pages per month
Processor and memory specifications
Printer processor
360MHz ARM4, ETM (16 bit)
Printer memory
  • 256 MB built-in RAM
  • 16 MB built-in Flash ROM
System requirements
For the most current information about supported operating systems and system requirements, visit www.hp.com/support/.
Client operating systems supported
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64 (Windows 7 Logo Program tested, Windows 7 Release Candidate 1, build 7100)
  • Mac OS X v10.5, v10.6
Server operating systems supported
  • Microsoft Windows Server 2008 Datacenter (SP1), Enterprise and Standard Editions
    • Architectures: x86 and x64
    • Services: Terminal Server, Cluster Server
  • Microsoft Windows Server 2003 (SP1 and later) Datacenter, Enterprise, and Standard Editions
  • Citrix Presentation Server 4.0 and 4.5
  • Citrix XenApp 5.0.1
  • Novell NetWare 6.5 SP7
  • Novell iPrint Client for Windows 5.12
  • Novell iPrint Client for Windows Vista 5.08
  • Novell iManager 2.7
  • Mac OS X v10.5.8, v10.6: PowerPC G4, G5, or Intel Core processor, 300 MB free hard disk space
Network protocol specifications
Network operating system compatibility
  • Windows XP (32-bit) (Professional and Home Editions), Windows Vista 32-bit and 64-bit (Ultimate Edition, Enterprise Edition and Business Edition), Windows 7 (32-bit and 64-bit)
  • Windows Small Business Server 2003 32-bit and 64-bit, Windows 2003 Server 32-bit and 64- bit, Windows 2003 Server R2 32-bit and 64-bit (Standard Edition, Enterprise Edition)
  • Windows Small Business Server 2008 64-bit, Windows 2008 Server 32-bit and 64-bit, Windows 2008 Server R2 64-bit (Standard Edition, Enterprise Edition)
  • Citrix XenDesktop 4
  • Citrix XenServer 5.5
  • Mac OS X v.10.5, v10.6
  • Microsoft Windows 2003 Server Terminal Services
  • Microsoft Windows 2003 Server Terminal Services with Citrix Presentation Server 4.0
  • Microsoft Windows 2003 Server Terminal Services with Citrix Presentation Server 4.5
  • Microsoft Windows 2003 Server Terminal Services with Citrix XenApp 5.0
  • Microsoft Windows 2003 Server Terminal Services with Citrix Metaframe XP with Feature Release 3
  • Microsoft Windows 2003 Small Business Server Terminal Services
  • Microsoft Windows Server 2008 Terminal Services
  • Microsoft Windows Small Business Server 2008 Terminal Services
  • Microsoft Windows 2008 Server Terminal Services with Citrix XenApp 5.0
  • Novell Netware 6.5, Open Enterprise Server 2
Compatible network protocols
TCP/IP
Network management
Embedded Web server (Ability to remotely configure and manage network printers)
Embedded Web server specifications
Requirements
  • A TCP/IP-based network (IPX/SPX-based networks are not supported)
  • A Web browser (either Microsoft Internet Explorer 7.0 or higher, Mozilla Firefox 3.0 or higher, Safari 3.0 or higher, or Google Chrome 3.0 or higher)
  • A network connection (you cannot use the embedded Web server connected directly to a computer with a USB cable)
  • An Internet connection (required for some features)
    You can open the embedded Web server without being connected to the Internet. However, some features are not available.
    The embedded Web server must be on the same side of a firewall as the printer.
Media specifications
Use these tables to determine the correct media to use with your printer, and determine what features work with your media.
Understand specifications for supported media
Use the tables to determine the correct media to use with your printer, and to determine what features work with your media.
Tray 2 is available with some models.
If you are using the duplexer, the minimum top and bottom margins must be at least 12 mm (0.47 inch).
Understand supported sizes
Media size
Tray 1
Tray 2
Duplexer
Standard media sizes
U.S. Letter (216 x 279 mm; 8.5 x 11 inches)
8.5 x 13 inches (216 x 330 mm)
U.S. Legal (216 x 356 mm; 8.5 x 14 inches)
A4 (210 x 297 mm; 8.3 x 11.7 inches)
U.S. Executive (184 x 267 mm; 7.25 x 10.5 inches)
U.S. Statement (140 x 216 mm; 5.5 x 8.5 inches)
B5 (JIS) (182 x 257 mm; 7.17 x 10.12 inches)
A5 (148 x 210 mm; 5.8 x 8.3 inches)
10 x 15 cm
16K (197 x 273 mm; 7.75 x 10.75 inches)
16K (195 x 270 mm; 7.7 x 10.6 inches)
16K (184 x 260 mm; 7.25 x 10.25 inches)
Envelopes
U.S. #10 Envelope (105 x 241 mm; 4.12 x 9.5 inches)
Monarch Envelope (98 x 191 mm; 3.88 x 7.5 inches)
B5 Envelope (176 x 250 mm; 6.7 x 9.8 inches)
DL Envelope (110 x 220 mm; 4.3 x 8.7 inches)
C5 Envelope (162 x 229 mm; 6.4 x 9 inches)
C6 Envelope (114 x 162 mm; 4.5 x 6.4 inches)
Japanese Envelope Chou #3 (120 x 235 mm; 4.7 x 9.3 inches)
Japanese Envelope Chou #4 (90 x 205 mm; 3.5 x 8.1 inches)
Cards / Photo Media
Index card (76.2 x 127 mm; 3 x 5 inches)
Index card (102 x 152 mm; 4 x 6 inches)
Index card (127 x 179 mm; 5 x 7 inches)
Index card (127 x 203 mm; 5 x 8 inches)
A6 card (105 x 148.5 mm; 4.13 x 5.83 inches)
Japanese Postcard (100 x 148 mm; 3.94 x 5.83 inches)
Double Japan Postcard Rotated (148 x 200 mm; 5.83 x 7.87 inches)
Other media
Custom-sized media between 76.2 to 216 mm wide and 127 to 356 mm long (3 to 8.5 inches wide and 5 to 14 inches long)
Understand supported media types and weights
Tray
Tray
Capacity
Tray 1
Paper
60 to 105 g/m2
(16 to 28 lb bond)
Up to 250 sheets of plain paper
(25 mm or 1 inch stacked)
Transparencies
Up to 70 sheets
(17 mm or 0.67 inch stacked)
Photo media
250 g/m2
(66 lb bond)
Up to 100 sheets
Labels
Up to 100 sheets
Envelopes
75 to 90 g/m2
(20 to 24 lb bond envelope)
Up to 30 sheets
Cards
Up to 200 g/m2
(110 lb index)
Up to 80 cards
Tray 2
Plain paper only
60 to 105 g/m2
(16 to 28 lb bond)
(25 mm or 1.0 inch stacked)
Duplexer
Paper
60 to 105 g/m2
(16 to 28 lb bond)
Not applicable
Output-bin
All supported media
Up to 150 sheets of plain paper (text printing)
Guidelines for printing on both sides of a page
  • Always use media that conforms to the printer specifications.
  • Specify two-sided printing options in your application or in the printer driver.
  • Do not print on both sides of transparencies, envelopes, photo paper, glossy media, or paper lighter than 16 lb bond (60 g/m2) or heavier than 28 lb bond (105 g/m2). Jams might occur with these media types.
  • Several kinds of media require a specific orientation when you print on both sides of a page. These include letterhead, preprinted paper, and paper with watermarks and prepunched holes. When you print from a computer running Windows, the printer prints the first side of the media first. Load the media with the print side facing down.
  • For auto-duplexing, when printing finishes on one side of the media, the printer holds the media and pauses while the ink dries. Once the ink dries, the media is pulled back into the printer and the second side is printed. When printing is complete, the media is dropped onto the output tray. Do not grab it before printing is complete.
  • You can print on both sides of supported custom-sized media by turning the media over and feeding it into the printer again.
Print specifications
Black print resolution
Up to 600 dpi with pigmented black ink
Color print resolution
Up to 600 dpi
Environmental specifications
Operating environment
Operating temperature: 5° to 40° C (41° to 104° F)
Recommended operating conditions: 15° to 32° C (59° to 90° F)
Recommended relative humidity: 25 to 75% non-condensing
Storage environment
Storage temperature: -40° to 60° C (-40° to 140° F)
Storage relative humidity: Up to 90% non-condensing at a temperature of 60° C (140° F)
Electrical specifications
Power supply
Universal power adapter (external)
Power requirements
Input voltage: 100 to 240 VAC (± 10%), 50/60 Hz (± 3Hz)
Output voltage: 32 Vdc at 2000 mA
Power consumption
21 watts printing (Draft Mode)
Acoustic emission specifications (print in Draft mode, noise levels per ISO 7779)
Sound pressure (bystander position)
LpAd 54 (dBA)
Sound power
LwAd 6.7 (BA)
