HP Officejet Pro 8000 Enterprise Printer Series - Understand the network configuration page
If the printer is connected to a network, you can print a network configuration page to view the network settings for the printer. You can use the network configuration page to help troubleshoot network connectivity problems. If you need to call HP, it is often useful to print this page before calling.
  1. General Information: Shows information about the current status and active connection type of the network, and other information, such as the URL of the embedded Web server.
  2. 802.3 Wired: Shows information about the active wired network connection, such as the IP address, subnet mask, default gateway, as well as the hardware address of the printer.
  3. Miscellaneous: Shows information about more advanced network settings.
    • Port 9100: The printer supports raw IP printing through TCP Port 9100. This HP-proprietary TCP/IP port on the printer is the default port for printing. It is accessed by HP software (for example, the HP Standard Port).
    • LPD: Line Printer Daemon (LPD) refers to the protocol and programs associated with line-printer spooling services that may be installed on various TCP/IP systems.
      The LPD functionality can be used with any host implementation of LPD that complies with the RFC 1179 document. The process for configuring printer spoolers, however, might differ. See your system documentation for information about configuring these systems.
    • Bonjour: Bonjour services (which use mDNS, or Multicast Domain Name System) are typically used on small networks for IP address and name resolution (through UDP port 5353), where a conventional DNS server is not used.
    • SLP: Service Location Protocol (SLP) is an Internet standard network protocol that provides a framework to allow networking applications to discover the existence, location, and configuration of networked services in enterprise networks. This protocol simplifies discovery and use of network resources such as printers, Web servers, fax machines, video cameras, files systems, backup devices (tape drives), databases, directories, mail servers, calendars.
    • Microsoft Web Services: Enable or disable the Microsoft Web Services Dynamic Discovery (WS Discovery) protocols or Microsoft Web Services for Devices (WSD) Print services supported on the printer. Disable unused print services to prevent access through those services.
      For more information about WS Discovery and WSD Print, visit www.microsoft.com.
    • SNMP: SNMP (Simple Network Management Protocol) is used by network management applications for printer management. The printer supports SNMPv1 protocol on IP networks.
    • WINS: If you have a Dynamic Host Configuration Protocol (DHCP) server on your network, the printer automatically obtains its IP address from that server and registers its name with any RFC 1001 and 1002-compliant dynamic name services as long as a WINS server IP address has been specified.
  4. Connected PC(s): Lists the computers connected to this printer, as well as the last time these computers accessed the printer.
    To print the Network Configuration page
    • Control panel: Press the OK button, select Information and then press the OK button. Press right arrow to select Network Configuration Page and then press the OK button.
      For models that are connected to a network, the network configuration page will also be printed.
    • HP Utility (Mac OS X): Click Device Information from the Information and Support panel, and then click Print Network Configuration Page.
    • Embedded Web Server: Click the Network tab, click Status in the left panel under Wired (802.3), and then click Network Configuration Page.
