    We are upgrading our website
HP Officejet Pro 8000 Enterprise Printer Series - Replace the ink cartridges
For information on recycling used ink supplies, see HP inkjet supplies recycling program. www.hp.com/hpinfo/globalcitizenship/environment/recycle/
If you do not already have replacement ink cartridges for the printer, you can order online by visiting www.hp.com/buy/supplies. If prompted, select your country/ region, follow the prompts to select your printer, and then the supplies you need.
At this time, some portions of the HP Web site are available in English only.
Wait until you have a new ink cartridge available before removing the old ink cartridge. Do not leave the ink cartridge outside of the printer for an extended period of time. This can result in damage to both the printer and the ink cartridge.
To replace the ink cartridges
Use these steps to replace the ink cartridges.
  1. Gently pull open the ink cartridge cover.
  2. Remove the ink cartridge that requires replacement by grasping it and pulling it firmly toward you.
  3. Remove the new ink cartridge from its package.
  4. Align the cartridge with its color-coded slot and insert the cartridge into the slot. Press down firmly on the cartridge to ensure proper contact.
  5. Close the ink cartridge cover.
