HP Elite 7200 Series Microtower PC - Troubleshooting Without Diagnostics
This chapter provides information on how to identify and correct minor problems, such as hard drive, optical drive, graphics, audio, memory, and software problems. If you encounter problems with the computer, refer to the tables in this chapter for probable causes and recommended solutions.
Safety and Comfort
  warning:
Misuse of the computer or failure to establish a safe and comfortable work environment may result in discomfort or serious injury. Refer to the Safety & Comfort Guide at http://www.hp.com/ergo for more information on choosing a workspace and creating a safe and comfortable work environment. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. For more information, refer to the Safety & Regulatory Information guide.
Before You Call for Technical Support
If you are having problems with the computer, try the appropriate solutions below to try to isolate the exact problem before calling for technical support.
  • Run the HP diagnostic tool.
  • Run the hard drive self-test in Computer Setup. Refer to the Computer Setup (F10) Utility Guide for more information.
  • Listen for beeps from the computer. The beeps are error codes that will help you diagnose the problem. Refer to Interpreting POST Audible Codes for more information.
  • If the screen is blank, plug the monitor into a different video port on the computer if one is available. Or, replace the monitor with a monitor that you know is functioning properly.
  • If you are working on a network, plug another computer with a different cable into the network connection. There may be a problem with the network plug or cable.
  • If you recently added new hardware, remove the hardware and see if the computer functions properly.
  • If you recently installed new software, uninstall the software and see if the computer functions properly.
  • Boot the computer to the Safe Mode to see if it will boot without all of the drivers loaded. When booting the operating system, use “Last Known Configuration.”
  • Refer to the comprehensive online technical support at http://www.hp.com/support.
  • Refer to Helpful Hints in this guide.
To assist you in resolving problems online, HP Instant Support Professional Edition provides you with self-solve diagnostics. If you need to contact HP support, use HP Instant Support Professional Edition's online chat feature. Access HP Instant Support Professional Edition at: http://www.hp.com/go/ispe.
Access the Business Support Center (BSC) at http://www.hp.com/go/bizsupport for the latest online support information, software and drivers, proactive notification, and worldwide community of peers and HP experts.
If it becomes necessary to call for technical assistance, be prepared to do the following to ensure that your service call is handled properly:
  • Be in front of your computer when you call.
  • Write down the computer serial number, product ID number, and monitor serial number before calling.
  • Spend time troubleshooting the problem with the service technician.
  • Remove any hardware that was recently added to your system.
  • Remove any software that was recently installed.
For sales information and warranty upgrades (Care Packs), call your local authorized service provider or dealer.
Helpful Hints
If you encounter problems with the computer, monitor, or software, see the following list of general suggestions before taking further action:
  • Check that the computer and monitor are plugged into a working electrical outlet.
  • Check that the voltage select switch (some models) is set to the appropriate voltage for your region (115V or 230V).
  • Check that the computer is turned on and the green power light is on.
  • Check that the monitor is turned on and the monitor light is on.
  • Turn up the brightness and contrast controls of the monitor if the monitor is dim.
  • Press and hold any key. If the system beeps, then the keyboard should be operating correctly.
  • Check all cable connections for loose connections or incorrect connections.
  • Wake the computer by pressing any key on the keyboard or pressing the power button. If the system remains in suspend mode, shut down the computer by pressing and holding the power button for at least four seconds then press the power button again to restart the computer. If the system will not shut down, unplug the power cord, wait a few seconds, then plug it in again. The computer will restart if it is set to power on automatically as soon as power is restored in Computer Setup. If it does not restart, press the power button to start the computer.
  • Reconfigure the computer after installing a non-plug and play expansion board or other option. See Solving Hardware Installation Problems for instructions.
  • Be sure that all the needed device drivers have been installed. For example, if you are using a printer, you need a driver for that model printer.
  • Remove all bootable media (CD or USB device) from the system before turning it on.
  • If you have installed an operating system other than the factory-installed operating system, check to be sure that it is supported on the system.
  • If the system has multiple video sources (embedded, PCI, or PCI-Express adapters) installed (embedded video on some models only) and a single monitor, the monitor must be plugged into the monitor connector on the source selected as the primary VGA adapter. During boot, the other monitor connectors are disabled and if the monitor is connected into these ports, the monitor will not function. You can select which source will be the default VGA source in Computer Setup.
When the computer is plugged into an AC power source, there is always voltage applied to the system board. You must disconnect the power cord from the power source before opening the computer to prevent system board or component damage.
Solving General Problems
You may be able to easily resolve the general problems described in this section. If a problem persists and you are unable to resolve it yourself or if you feel uncomfortable about performing the operation, contact an authorized dealer or reseller.
  warning:
When the computer is plugged into an AC power source, voltage is always applied to the system board. To reduce the risk of personal injury from electrical shock and/or hot surfaces, be sure to disconnect the power cord from the wall outlet and allow the internal system components to cool before touching.
Computer appears locked up and will not turn off when the power button is pressed.
Cause
Solution
Software control of the power switch is not functional.
  1. Press and hold the power button for at least four seconds until the computer turns off.
  2. Disconnect the power cord from the electrical outlet.
Computer will not respond to USB keyboard or mouse.
Cause
Solution
Computer is in standby mode.
To resume from standby mode, press the power button or press any key.
When attempting to resume from standby mode, do not hold down the power button for more than four seconds. Otherwise, the computer will shut down and you will lose any unsaved data.
System has locked up.
Restart computer.
Computer date and time display is incorrect.
Cause
Solution
RTC (real-time clock) battery may need to be replaced.
Connecting the computer to a live AC outlet prolongs the life of the RTC battery.
First, reset the date and time under Control Panel (Computer Setup can also be used to update the RTC date and time). If the problem persists, replace the RTC battery. See the Hardware Reference Guide for instructions on installing a new battery, or contact an authorized dealer or reseller for RTC battery replacement.
Cursor will not move using the arrow keys on the keypad.
Cause
Solution
The Num Lock key may be on.
Press the Num Lock key. The Num Lock light should not be on if you want to use the arrow keys. The Num Lock key can be disabled (or enabled) in Computer Setup.
There is no sound or sound volume is too low.
Cause
Solution
System volume may be set low or muted.
  1. Check the F10 BIOS settings to make sure the internal system speaker is not muted (this setting does not affect the external speakers).
  2. Make sure the external speakers are properly connected and powered on and that the speakers' volume control is set correctly.
  3. Use the system volume control available in the operating system to make sure the speakers are not muted or to increase the volume.
Cannot remove computer cover or access panel.
Cause
Solution
Smart Cover Lock, featured on some computers, is locked.
Unlock the Smart Cover Lock using Computer Setup.
The Smart Cover FailSafe Key, a device for manually disabling the Smart Cover Lock, is available from HP. You will need the FailSafe Key in case of forgotten password, power loss, or computer malfunction. Order PN 166527-001 for the wrench-style key or PN 166527-002 for the screwdriver bit key.
Poor performance is experienced.
Cause
Solution
Processor is hot.
  1. Make sure airflow to the computer is not blocked. Leave a 10.2-cm (4-inch) clearance on all vented sides of the computer and above the monitor to permit the required airflow.
  2. Make sure fans are connected and working properly (some fans only operate when needed).
  3. Make sure the processor heatsink is installed properly.
Hard drive is full.
Transfer data from the hard drive to create more space on the hard drive.
Low on memory.
Add more memory.
Hard drive fragmented.
Defragment hard drive.
Program previously accessed did not release reserved memory back to the system.
Restart the computer.
Virus resident on the hard drive.
Run virus protection program.
Too many applications running.
  1. Close unnecessary applications to free up memory.
  2. Add more memory. Some applications run in the background and can be closed by right-clicking on their corresponding icons in the task tray. To prevent these applications from launching at startup, go to Start > Run (Windows XP), Start > Accessories > Run (Windows Vista), or click on the Windows 7 start icon in the bottom left corner of the screen (Windows 7) and type msconfig. On the Startup tab of the System Configuration Utility, clear applications that you do not want to launch automatically.
Some software applications, especially games, are stressful on the graphics subsystem
  1. Lower the display resolution for the current application or consult the documentation that came with the application for suggestions on how to improve performance by adjusting parameters in the application.
  2. Add more memory.
  3. Upgrade the graphics solution.
Cause unknown.
System does not power on.
Cause
Solution
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
  1. Check that the voltage selector, located on the rear of the power supply on some models, is set to the appropriate voltage. Proper voltage setting depends on your region.
  2. Remove the expansion cards one at a time and see if the system powers on.
  3. Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
  1. Check that the unit is plugged into a working AC outlet.
  2. Open hood and check that the power button harness is properly connected to the system board.
  3. Check that both power supply cables are properly connected to the system board.
  4. Replace the power button harness.
  5. Replace the power supply.
  6. Replace the system board.
Solving Power Problems
Common causes and solutions for power problems are listed in the following table.
Power supply shuts down intermittently.
Cause
Solution
Voltage selector switch on rear of computer chassis (some models) not switched to correct line voltage (115V or 230V).
Select the proper AC voltage using the selector switch.
Power supply will not turn on because of internal power supply fault.
Contact an authorized service provider to replace the power supply.
Computer powered off automatically.
Cause
Solution
Processor thermal protection activated:
A fan may be blocked or not turning.
OR
The heatsink is not properly attached to the processor.
  1. Ensure that the computer air vents are not blocked and the processor cooling fan is running.
  2. Open hood, press power button, and see if the processor fan spins. If the processor fan is not spinning, make sure the fan's cable is plugged onto the system board header.
  3. If fan is plugged in, but is not spinning, then replace the heatsink/fan assembly.
  4. Contact an authorized reseller or service provider.
Power failure (power supply is overloaded).
  1. Check that the voltage selector, located on the rear of the power supply (some models), is set to the appropriate voltage. Proper voltage setting depends on your region.
  2. Open the hood and ensure the power supply cable is seated into the connector on the system board.
  3. Check if a device is causing the problem by removing ALL attached devices (such as hard drives or optical drives, and expansion cards). Power on the system. If the system enters the POST, then power off and replace one device at a time and repeat this procedure until failure occurs. Replace the device that is causing the failure. Continue adding devices one at a time to ensure all devices are functioning properly.
  4. Replace the power supply.
  5. Replace the system board.
Solving Hard Drive Problems
Hard drive error occurs.
Cause
Solution
Hard disk has bad sectors or has failed.
  1. In Microsoft Windows XP, right-click Start, click Explore, and select a drive. Select File > Properties > Tools. Under Error-checking, click Check Now.
    In Microsoft Windows Vista and Windows 7, right-click Start, click Explore, and right-click on a drive. Select Properties then select the Tools tab. Under Error-checking click Check Now.
  2. Use a utility to locate and block usage of bad sectors. If necessary, reformat the hard disk.
Disk transaction problem.
Cause
Solution
Either the directory structure is bad or there is a problem with a file.
Drive not found (identified).
Cause
Solution
Cable could be loose.
Check cable connections.
The system may not have automatically recognized a newly installed device.
See reconfiguration directions in the Solving Hardware Installation Problems section. If the system still does not recognize the new device, check to see if the device is listed within Computer Setup. If it is listed, the probable cause is a driver problem. If it is not listed, the probable cause is a hardware problem.
The device is attached to a SATA port that has been disabled in Computer Setup.
Run the Computer Setup utility and ensure SATA1 Controller is Enabled in the Advanced menu.
Computer will not boot from hard drive.
Cause
Solution
Boot order is not correct.
Run the Computer Setup utility and change boot sequence in Boot > Boot Device Priority.
Hard drive is damaged.
See the Worldwide Limited Warranty for terms and conditions.
Computer seems to be locked up.
Cause
Solution
Program in use has stopped responding to commands.
Attempt the normal Windows “Shut Down” procedure. If this fails, press the power button for four or more seconds to turn off the power. To restart the computer, press the power button again.
Solving Media Card Reader Problems
Media card will not work in a digital camera after formatting it in Microsoft Windows XP or Microsoft Windows Vista.
Cause
Solution
By default, Windows XP and Windows Vista will format any media card with a capacity greater than 32MB with the FAT32 format. Most digital cameras use the FAT (FAT16 & FAT12) format and can not operate with a FAT32 formatted card.
Either format the media card in the digital camera or select FAT file system to format the media card in a computer with Windows XP or Windows Vista.
A write-protected or locked error occurs when attempting to write to the media card.
Cause
Solution
Media card is locked. Locking the media card is a safety feature that prevents writing to and deleting from an SD/Memory Stick/PRO card.
If using an SD card, make sure that the lock tab located on the right of the SD card is not in the locked position. If using a Memory Stick/PRO card, make sure that the lock tab located on the bottom of the Memory Stick/PRO card is not in the locked position.
Can not write to the media card.
Cause
Solution
The media card is a read-only memory (ROM) card.
Check the manufacturer’s documentation included with your card to see if it writable. Refer to the previous section for a list of compatible cards.
Unable to access data on the media card after inserting it into a slot.
Cause
Solution
The media card is not inserted properly, is inserted in the wrong slot, or is not supported.
Ensure that the card is inserted properly with the gold contact on the correct side. The green LED will light if inserted properly.
Do not know how to remove a media card correctly.
Cause
Solution
The computer’s software is used to safely eject the card.
Open My Computer (Windows XP), Computer (Windows Vista), or Devices and Printers (Windows 7), right-click on the corresponding drive icon, and select Eject. Then pull the card out of the slot.
Never remove the card when the green LED is flashing
After installing the media card reader and booting to Windows, the reader and the inserted cards are not recognized by the computer.
Cause
Solution
The operating system needs time to recognize the device if the reader was just installed into the computer and you are turning the PC on for the first time.
Wait a few seconds so that the operating system can recognize the reader and the available ports, and then recognize whatever media is inserted in the reader.
After inserting a media card in the reader, the computer attempts to boot from the media card.
Cause
Solution
The inserted media card has boot capability.
If you do not want to boot from the media card, remove it during boot or do not select the option to boot from the inserted media card during the boot process.
Solving Display Problems
If you encounter display problems, see the documentation that came with the monitor and the common causes and solutions listed in the following table.
Blank screen (no video).
Cause
Solution
Monitor is not turned on and the monitor light is not on.
Turn on the monitor and check that the monitor light is on.
Bad monitor.
Try a different monitor.
The cable connections are not correct.
Check the cable connection from the monitor to the computer and to the electrical outlet.
You may have a screen blanking utility installed or energy saver features are enabled.
Press any key or click the mouse button and, if set, type your password.
You are using a fixed-sync monitor and it will not sync at the resolution chosen.
Be sure that the monitor can accept the same horizontal scan rate as the resolution chosen.
Press the power button to resume from standby mode.
Monitor settings in the computer are not compatible with the monitor.
  1. In Windows XP Control Panel, double-click the Display icon and select the Settings tab.
    In Windows Vista Control Panel, under Appearance and Personalization, select Adjust screen resolution.
    In Windows 7, right click in an empty space on the desktop and select Screen Resolution.
  2. Use the sliding control to reset the resolution.
Monitor is configured to use an input that is not active.
Use the monitor's on-screen menu controls to select the input that is being driven by the system. Refer to the monitor's user documentation for more information on the on-screen controls and settings.
Cannot enable integrated graphics after installing a PCI Express graphics card.
Cause
Solution
On systems with Intel integrated graphics, the integrated graphics cannot be enabled after installing a PCI Express x16.
The integrated graphics can be enabled in Computer Setup if a PCI Express x1 graphics card is installed, but it cannot be enabled if there is a graphics card in the PCI Express x16 slot.
Blank screen and the computer emits one short beep then one long beep followed by a three second pause.
Cause
Solution
Pre-video memory error.
  1. Reseat DIMMs. Power on the system.
  2. Replace DIMMs one at a time to isolate the faulty module.
  3. Replace third-party memory with HP memory.
  4. Replace the system board.
Blank screen and the computer emits two short beeps then one long beep followed by a three second pause.
Cause
Solution
Pre-video graphics error.
For systems with a graphics card:
  1. Reseat the graphics card. Power on the system.
  2. Replace the graphics card.
For systems with integrated graphics, replace the system board.
Monitor does not function properly when used with energy saver features.
Cause
Solution
Monitor without energy saver capabilities is being used with energy saver features enabled.
Disable monitor energy saver feature.
Dim characters.
Cause
Solution
The brightness and contrast controls are not set properly.
Adjust the monitor brightness and contrast controls.
Cables are not properly connected.
Check that the graphics cable is securely connected to the graphics card and the monitor.
Blurry video or requested resolution cannot be set.
Cause
Solution
If the graphics controller was upgraded, the correct graphics drivers may not be loaded.
Install the video drivers included in the upgrade kit.
Monitor is not capable of displaying requested resolution.
Change requested resolution.
Graphics card is bad.
The picture is broken up, rolls, jitters, or flashes.
Cause
Solution
The monitor connections may be incomplete or the monitor may be incorrectly adjusted.
  1. Be sure the monitor cable is securely connected to the computer.
  2. In a two-monitor system or if another monitor is in close proximity, be sure the monitors are not interfering with each other’s electromagnetic field by moving them apart.
  3. Fluorescent lights or fans may be too close to the monitor.
Monitor needs to be degaussed.
Degauss the monitor. Refer to the documentation that came with the monitor for instructions.
Image is not centered.
Cause
Solution
Position may need adjustment.
Press the monitor's Menu button to access the OSD menu. Select ImageControl/ Horizontal Position or Vertical Position to adjust the horizontal or vertical position of the image.
“No Connection, Check Signal Cable” displays on screen.
Cause
Solution
Monitor video cable is disconnected.
Connect the video cable between the monitor and computer.
Ensure that the computer power is off while connecting the video cable.
“Out of Range” displays on screen.
Cause
Solution
Video resolution and refresh rate are set higher than what the monitor supports.
Restart the computer and enter Safe Mode. Change the settings to a supported setting then restart the computer so that the new settings take effect.
Vibrating or rattling noise coming from inside a CRT monitor when powered on.
Cause
Solution
Monitor degaussing coil has been activated.
None. It is normal for the degaussing coil to be activated when the monitor is powered on.
Clicking noise coming from inside a CRT monitor.
Cause
Solution
Electronic relays have been activated inside the monitor.
None. It is normal for some monitors to make a clicking noise when turned on and off, when going in and out of standby mode, and when changing resolutions.
High pitched noise coming from inside a flat panel monitor.
Cause
Solution
Brightness and/or contrast settings are too high.
Lower brightness and/or contrast settings.
Fuzzy focus; streaking, ghosting, or shadowing effects; horizontal scrolling lines; faint vertical bars; or unable to center the picture on the screen (flat panel monitors using an analog VGA input connection only).
Cause
Solution
Flat panel monitor’s internal digital conversion circuits may be unable to correctly interpret the output synchronization of the graphics card.
  1. Select the monitor’s Auto-Adjustment option in the monitor’s on-screen display menu.
  2. Manually synchronize the Clock and Clock Phase on-screen display functions.
Graphics card is not seated properly or is bad.
Certain typed symbols do not appear correct.
Cause
Solution
The font you are using does not support that particular symbol.
Use the Character Map to locate and select the appropriate symbol. Click Start > All Programs > Accessories > System Tools > Character Map. You can copy the symbol from the Character Map into a document.
Solving Audio Problems
If the computer has audio features and you encounter audio problems, see the common causes and solutions listed in the following table.
Sound cuts in and out.
Cause
Solution
Processor resources are being used by other open applications.
Shut down all open processor-intensive applications.
Direct sound latency, common in many media player applications.
In Windows XP only:
  1. From the Control Panel, select Sounds and Audio Devices.
  2. On the Audio tab, select a device from the Sound Playback list.
  3. Click the Advanced button and select the Performance tab.
  4. Set the Hardware acceleration slider to None and the Sample rate conversion quality slider to Good and retest the audio.
  5. Set the Hardware acceleration slider to Full and the Sample rate conversion quality slider to Best and retest the audio.
Sound does not come out of the speaker or headphones.
Cause
Solution
Software volume control is turned down or muted.
Double-click the Speaker icon on the taskbar, then make sure that Mute is not selected and use the volume slider to adjust the volume.
The external speakers are not turned on.
Turn on the external speakers.
The audio device may be connected to the wrong jack.
Ensure that the device is connected to the correct jack on the computer. The speakers should be plugged into the rear line-out jack and the headphones should be plugged into the front headphone jack.
External speakers plugged into the wrong audio jack on a recently installed sound card.
See the sound card documentation for proper speaker connection.
Digital CD audio is not enabled.
Enable digital CD audio. In the Device Manager, right-click on the CD/DVD device and select Properties. Make sure Enable digital CD audio for this CD-ROM device is checked.
Headphones or devices connected to the line-out connector mute the internal speaker.
Turn on and use headphones or external speakers, if connected, or disconnect headphones or external speakers.
Internal speaker is disabled in Computer Setup.
Enable the internal speaker in Computer Setup. Select Advanced > Internal Speaker.
Sound from headphones is not clear or muffled.
Cause
Solution
Headphones are plugged into the rear audio output connector. The rear audio output connector is for powered audio devices and is not designed for headphone use.
Plug the headphones into the headphone connector on the front of the computer.
Computer appears to be locked up while recording audio.
Cause
Solution
The hard disk may be full.
Before recording, make sure there is enough free space on the hard disk. You can also try recording the audio file in a compressed format.
Solving Printer Problems
If you encounter printer problems, see the documentation that came with the printer and the common causes and solutions listed in the following table.
Printer will not print.
Cause
Solution
Printer is not turned on and online.
Turn the printer on and make sure it is online.
The correct printer drivers for the application are not installed.
  1. Install the correct printer driver for the application.
  2. Try printing using the MS-DOS command:
DIR C:\ > [printer port]
where [printer port] is the address of the printer being used. If the printer works, reload the printer driver.
If you are on a network, you may not have made the connection to the printer.
Make the proper network connections to the printer.
Printer may have failed.
Run printer self-test.
Printer will not turn on.
Cause
Solution
The cables may not be connected properly.
Reconnect all cables and check the power cord and electrical outlet.
Printer prints garbled information.
Cause
Solution
The correct printer driver for the application is not installed.
Reconnect all cables.
Printer memory may be overloaded.
Reset the printer by turning it off for one minute, then turn it back on.
Printer is offline.
Cause
Solution
The printer may be out of paper.
Check the paper tray and refill it if it is empty. Select online.
Solving Keyboard and Mouse Problems
If you encounter keyboard or mouse problems, see the documentation that came with the equipment and the common causes and solutions listed in the following table.
Solving Keyboard Problems
Keyboard commands and typing are not recognized by the computer.
Cause
Solution
Keyboard connector is not properly connected.
  1. On the Windows XP Desktop, click Start > Shut Down.
    On the Windows Vista or Windows 7 desktop, click Start, click the arrow on the lower right corner of the Start menu, then select Shut Down.
  2. After the shutdown is complete, reconnect the keyboard to the back of the computer and restart the computer.
Shut down your computer using the mouse and then restart the computer.
Keyboard needs repairs.
Cause
Solution
Solving Mouse Problems
Mouse does not respond to movement or is too slow.
Cause
Solution
Mouse connector is not properly plugged into the back of the computer.
Shut down the computer using the keyboard.
  1. Press the Ctrl and Esc keys at the same time (or press the Windows logo key) to display the Start menu.
  2. Use the arrow keys to select Shut Down and then press the Enter key.
  3. After the shutdown is complete, plug the mouse connector into the back of the computer (or the keyboard) and restart.
Shut down the computer using the keyboard then restart the computer.
Mouse may need cleaning.
Remove the roller ball cover on the mouse and clean the internal components.
Mouse may need repair.
Mouse will only move vertically, horizontally, or movement is jerky.
Cause
Solution
Mouse roller ball or the rotating encoder shafts that make contact with the ball are dirty.
Remove roller ball cover from the bottom of the mouse and clean the internal components with a mouse cleaning kit available from most computer stores.
You may need to reconfigure the computer when you add or remove hardware, such as an additional drive or expansion card. If you install a plug and play device, Windows automatically recognizes the device and configures the computer. If you install a non–plug and play device, you must reconfigure the computer after completing installation of the new hardware. In Windows, use the Add Hardware Wizard and follow the instructions that appear on the screen.
  warning:
A new device is not recognized as part of the system.
Cause
Solution
Device is not seated or connected properly.
Ensure that the device is properly and securely connected and that pins in the connector are not bent down.
Cable(s) of new external device are loose or power cables are unplugged.
Ensure that all cables are properly and securely connected and that pins in the cable or connector are not bent down.
Power switch of new external device is not turned on.
Turn off the computer, turn on the external device, then turn on the computer to integrate the device with the computer system.
When the system advised you of changes to the configuration, you did not accept them.
Reboot the computer and follow the instructions for accepting the changes.
A plug and play board may not automatically configure when added if the default configuration conflicts with other devices.
Use Windows Device Manager to deselect the automatic settings for the board and choose a basic configuration that does not cause a resource conflict. You can also use Computer Setup to reconfigure or disable devices to resolve the resource conflict.
USB ports on the computer are disabled in Computer Setup.
Enter Computer Setup (F10) and enable the USB ports in Advanced > USB Ports.
1394 ports on the computer are disabled in Computer Setup.
Enter Computer Setup (F10) and enable the 1394 ports in Advanced > Onboard 1394.
Computer will not start.
Cause
Solution
Wrong memory modules were used in the upgrade or memory modules were installed in the wrong location.
  1. Review the documentation that came with the system to determine if you are using the correct memory modules and to verify the proper installation.
    DIMM2 must always be installed.
  2. Listen for beeps from the computer. Beeps are codes for specific problems.
  3. If you still cannot resolve the issue, contact Customer Support.
The computer emits one short beep then one long beep followed by a three second pause.
Cause
Solution
Memory is installed incorrectly or is bad.
To avoid damage to the DIMMs or the system board, you must unplug the computer power cord before attempting to reseat, install, or remove a DIMM.
The computer emits two short beeps then one long beep followed by a three second pause.
Cause
Solution
Graphics card is not seated properly or is bad, or system board is bad.
Solving Network Problems
Some common causes and solutions for network problems are listed in the following table. These guidelines do not discuss the process of debugging the network cabling.
Wake-on-LAN feature is not functioning.
Cause
Solution
Wake-on-LAN is not enabled.
To enable Wake-on-LAN in Windows XP:
  1. Select Start > Control Panel.
  2. Double-click Network Connections.
  3. Double-click Local Area Connection.
  4. Click Properties.
  5. Click Configure.
  6. Click the Power Management tab, then select the check box to Allow this device to bring the computer out of standby.
To enable Wake-on-LAN in Windows Vista:
  2. Under Network and Internet, select View network status and tasks.
  3. In the Tasks list, select Manage network connections.
  4. Double-click Local Area Connection.
  5. Click the Properties button.
  6. Click the Configure button.
  7. Click the Power Management tab, then select the check box to Allow this device to wake the computer.
To enable Wake-on-LAN in Windows 7:
  2. Under Network and Sharing Center, click Change adapter settings.
  3. Right-click the network connection you want to enable WOL on and click Properties.
  4. Click Configure.
  5. Select Allow this device to wake the computer.
  6. Click OK.
Network driver does not detect network controller.
Cause
Solution
Network controller is disabled.
  1. Run Computer Setup and enable network controller in Advanced > Onboard LAN.
  2. Enable the network controller in the operating system via Device Manager.
Incorrect network driver.
Check the network controller documentation for the correct driver or obtain the latest driver from the manufacturer’s Web site.
Network status link light never flashes.
The network status light is supposed to flash when there is network activity.
Cause
Solution
No active network is detected.
Check cabling and network equipment for proper connection.
Network controller is not set up properly.
Check for the device status within Windows, such as Device Manager for driver load and the Network Connections applet within Windows for link status.
Network driver is not properly loaded.
Reinstall network drivers.
System cannot autosense the network.
Disable auto-sensing capabilities and force the system into the correct operating mode.
Diagnostics reports a failure.
Cause
Solution
The cable is not securely connected.
Ensure that the cable is securely attached to the network connector and that the other end of the cable is securely attached to the correct device.
The cable is attached to the incorrect connector.
Ensure that the cable is attached to the correct connector.
There is a problem with the cable or a device at the other end of the cable.
Ensure that the cable and device at the other end are operating correctly.
The network controller is defective.
Contact an authorized service provider.
Diagnostics passes, but the computer does not communicate with the network.
Cause
Solution
Network drivers are not loaded, or driver parameters do not match current configuration.
Make sure the network drivers are loaded and that the driver parameters match the configuration of the network controller.
Make sure the correct network client and protocol is installed.
The network controller is not configured for this computer.
Select the Network icon in the Control Panel and configure the network controller.
Network controller stops working without apparent cause.
Cause
Solution
The files containing the network drivers are corrupted.
Reinstall the network drivers.
New network card will not boot.
Cause
Solution
New network card may be defective or may not meet industry-standard specifications.
Install a working, industry-standard NIC, or change the boot sequence to boot from another source.
Cannot connect to network server when attempting Remote System Installation.
Cause
Solution
The network controller is not configured properly.
Verify Network Connectivity, that a DHCP Server is present, and that the Remote System Installation Server contains the NIC drivers for your NIC.
System setup utility reports unprogrammed EEPROM.
Cause
Solution
Unprogrammed EEPROM.
Solving Memory Problems
If you encounter memory problems, some common causes and solutions are listed in the following table.
Power may still be supplied to the DIMMs when the computer is turned off. To avoid damage to the DIMMs or the system board, you must unplug the computer power cord before attempting to reseat, install, or remove a DIMM.
For those systems that support ECC memory, HP does not support mixing ECC and non-ECC memory. Otherwise, the computer will not boot the operating system.
System will not boot or does not function properly after installing additional memory modules.
Cause
Solution
A memory module is not installed in the DIMM2 socket.
Ensure that a memory module is installed in the blue DIMM2 socket on the system board. This socket must be populated with a memory module.
Memory module is not the correct type or speed grade for the system or the new memory module is not seated properly.
Replace module with the correct industry-standard device for the computer. On some models, ECC and non-ECC memory modules cannot be mixed.
Out of memory error.
Cause
Solution
Memory configuration may not be set up correctly.
Use the Device Manager to check memory configuration.
You have run out of memory to run the application.
Check the application documentation to determine the memory requirements.
Memory count during POST is wrong.
Cause
Solution
The memory modules may not be installed correctly.
Check that the memory modules have been installed correctly and that proper modules are used.
Integrated graphics may use system memory.
No action required.
Insufficient memory error during operation.
Cause
Solution
Too many Terminate and Stay Resident programs (TSRs) are installed.
Delete any TSRs that you do not need.
You have run out of memory for the application.
Check the memory requirements for the application or add more memory to the computer.
Cause
Solution
Solving CD-ROM and DVD Problems
If you encounter CD-ROM or DVD problems, see the common causes and solutions listed in the following table or to the documentation that came with the optional device.
System will not boot from CD-ROM or DVD drive.
Cause
Solution
The device is attached to a SATA port that has been disabled in the Computer Setup utility.
Non-bootable CD in drive.
Try a bootable CD in the drive.
Boot order not correct.
  1. Run the Computer Setup utility and change the optical drive boot priority in Boot > Boot Device Priority > CD-ROM Group Boot Priority.
  2. Run the Computer Setup utility and change boot group sequence in Boot > Boot Device Priority.
Cause
Solution
CD-ROM or DVD devices are not detected or driver is not loaded.
Cause
Solution
Drive is not connected properly or not properly configured.
See the documentation that came with the optional device.
Movie will not play in the DVD drive.
Cause
Solution
Movie may be regionalized for a different country.
See the documentation that came with the DVD drive.
Decoder software is not installed.
Install decoder software.
Damaged media.
Replace media.
Movie rating locked out by parental lock.
Use DVD software to remove parental lock.
Media installed upside down.
Reinstall media.
Cannot eject compact disc (tray-load unit).
Cause
Solution
Disc not properly seated in the drive.
Turn off the computer and insert a thin metal rod into the emergency eject hole and push firmly. Slowly pull the tray out from the drive until the tray is fully extended, then remove the disc.
CD-ROM, CD-RW, DVD-ROM, or DVD-R/RW drive cannot read a disc or takes too long to start.
Cause
Solution
Media has been inserted upside down.
Re-insert the media with the label facing up.
The DVD-ROM drive takes longer to start because it has to determine the type of media played, such as audio or video.
Wait at least 30 seconds to let the DVD-ROM drive determine the type of media being played. If the disc still does not start, read the other solutions listed for this topic.
CD or DVD disc is dirty.
Clean CD or DVD with a CD cleaning kit, available from most computer stores.
Windows does not detect the CD-ROM or DVD-ROM drive.
  1. Use Device Manager to remove or uninstall the device.
  2. Restart the computer and let Windows detect the CD or DVD driver.
Recording or copying CDs is difficult or impossible.
Cause
Solution
Wrong or poor quality media type.
  1. Try using a slower speed when recording.
  2. Verify that you are using the correct media for the drive.
  3. Try a different brand of media. Quality varies widely between manufacturers.
Solving USB Flash Drive Problems
If you encounter USB flash drive problems, common causes and solutions are listed in the following table.
USB flash drive is not seen as a drive letter in Windows.
Cause
Solution
The drive letter after the last physical drive is not available.
Change the default drive letter for the flash drive in Windows.
USB flash drive not found (identified).
Cause
Solution
The device is attached to a USB port that has been disabled in Computer Setup.
Run the Computer Setup utility and ensure USB Ports are Enabled in the Advanced menu.
The device was not properly seated before power-up.
Ensure the device is fully inserted into the USB port before applying power to the system
System will not boot from USB flash drive.
Cause
Solution
  1. Run the Computer Setup utility and change the removable media boot priority in Boot > Boot Device Priority.
The image on the device is not bootable.
Follow the procedures described in the "Replicating the Setup" section of the Service Reference Guide.
The computer boots to DOS after making a bootable flash drive.
Cause
Solution
Flash drive is bootable.
Install the flash drive only after the operating system boots.
Solving Front Panel Component Problems
If you encounter problems with devices connected to the front panel, refer to the common causes and solutions listed in the following table.
A USB device, 1394 device, headphone, or microphone is not recognized by the computer.
Cause
Solution
Device is not properly connected.
  1. Turn off the computer.
  2. Reconnect the device to the front of the computer and restart the computer.
The device does not have power.
If the USB device requires AC power, be sure one end is connected to the device and one end is connected to a live outlet.
The correct device driver is not installed.
  1. Install the correct driver for the device.
  2. You might need to reboot the computer.
The cable from the device to the computer does not work.
  1. If possible, replace the cable.
  2. Restart the computer.
The device is not working.
  1. Replace the device.
Solving Internet Access Problems
If you encounter Internet access problems, consult your Internet Service Provider (ISP) or refer to the common causes and solutions listed in the following table.
Unable to connect to the Internet.
Cause
Solution
Internet Service Provider (ISP) account is not set up properly.
Verify Internet settings or contact your ISP for assistance.
Modem is not set up properly.
Reconnect the modem. Verify the connections are correct using the quick setup documentation.
Web browser is not set up properly.
Verify that the Web browser is installed and set up to work with your ISP.
Cable/DSL modem is not plugged in.
Plug in cable/DSL modem. You should see a “power” LED light on the front of the cable/DSL modem.
Cable/DSL service is not available or has been interrupted due to bad weather.
Try connecting to the Internet at a later time or contact your ISP. (If the cable/DSL service is connected, the “cable” LED light on the front of the cable/DSL modem will be on.)
The CAT5 UTP cable is disconnected.
Connect the CAT5 UTP cable between the cable modem and the computers’s RJ-45 connector. (If the connection is good, the “PC” LED light on the front of the cable/DSL modem will be on.)
IP address is not configured properly.
Contact your ISP for the correct IP address.
Cookies are corrupted. (A “cookie” is a small piece of information that a Web server can store temporarily with the Web browser. This is useful for having the browser remember some specific information that the Web server can later retrieve.)
Windows Vista
  2. Click Network and Internet.
  3. Click Internet Options.
  4. In the Browsing history section on the General tab, click the Delete button.
  5. Click the Delete cookies button.
Windows XP
  2. Double-click Internet Options.
  3. On the General tab, click the Delete Cookies button.
Windows 7
  2. Click Internet Options.
  3. In the Browsing history section on the General tab, click the Delete button.
  4. Click the Delete cookies button.
Cannot automatically launch Internet programs.
Cause
Solution
You must log on to your ISP before some programs will start.
Log on to your ISP and launch the desired program.
Internet takes too long to download Web sites.
Cause
Solution
Verify that the modem is connected and communicating properly.
Windows XP
  2. Double-click System.
  3. Click the Hardware tab.
  4. In the Device Manager area, click the Device Manager button.
  5. Double-click Modems.
  6. Double-click Agere Systems PCI-SV92PP Soft Modem.
  7. On the General tab, click Diagnostics.
  8. Click Query Modem. A “Success” response indicates the modem is connected and working properly.
Windows Vista
  2. Click on System and Maintenance.
  3. Click on System.
  4. In the Tasks list, select Device Manager.
Windows 7
  2. Click on System.
  3. In the Tasks list, select Device Manager.
  4. Double-click Modems.
  5. Double-click Agere Systems PCI-SV92PP Soft Modem.
  6. On the General tab, click Diagnostics.
  7. Click Query Modem. A “Success” response indicates the modem is connected and working properly.
Solving Software Problems
Most software problems occur as a result of the following:
  • The application was not installed or configured correctly.
  • There is insufficient memory available to run the application.
  • There is a conflict between applications.
  • If you have installed an operating system other than the factory-installed operating system, check to be sure it is supported on the system.
If you encounter software problems, see the applicable solutions listed in the following table.
Computer will not continue and no HP logo screen has appeared.
Cause
Solution
POST error has occurred.
See the Restore Kit or the Worldwide Limited Warranty for terms and conditions.
Computer will not continue after HP logo screen has appeared.
Cause
Solution
System files may be damaged.
Scan hard drive for errors.
“Illegal Operation has Occurred” error message is displayed.
Cause
Solution
Software being used is not Microsoft-certified for your version of Windows.
Verify that the software is certified by Microsoft for your version of Windows (see program packaging for this information).
Configuration files are corrupt.
If possible, save all data, close all programs, and restart the computer.
This section covers the audible codes that may occur before or during POST that do not necessarily have an error code or text message associated with them.
  warning:
Beeps
Meaning
Recommended Action
1 short beep and 1 long beep followed by a three second pause
Bad memory or memory configuration error.
2 short beeps and 1 long beep followed by a three second pause
No graphics card installed or graphics card initialization failed.
3 short beeps and 1 long beep followed by a three second pause
CPU configuration error or invalid CPU detected before graphics card initialized.
  1. Upgrade the BIOS to proper version.
  2. Change the processor.
1 short beep followed by a one second pause
No optical drive found.
  1. Check cable connections.
  2. Run the Computer Setup utility and ensure the device port is enabled.
2 short beeps followed by a three second pause
No CD found.
  1. Check the type of drive that you are using and use the correct media type.
  2. Replace the CD with a new one.
3 short beeps followed by a three second pause
Flashing not ready (missing utility or BIOS image file, etc.)
4 short beeps followed by a three second pause
Flashing operation has failed (checksum error, corrupted image, etc.)
  1. Verify the correct ROM.
  2. Flash the ROM if needed.
  3. If an expansion board was recently added, remove it to see if the problem remains.
  4. Clear CMOS.
  5. If the message disappears, there may be a problem with the expansion card.
5 short beeps followed by a three second pause
BIOS recovery was successful
No action required.
Resetting the Password Jumper
To disable the power-on or setup password features, or to clear the power-on or setup passwords, complete the following steps:
  1. Shut down the operating system properly, then turn off the computer and any external devices, and disconnect the power cord from the power outlet.
  2. With the power cord disconnected, press the power button again to drain the system of any residual power.
      warning:
    To reduce the risk of personal injury from electrical shock and/or hot surfaces, be sure to disconnect the power cord from the wall outlet, and allow the internal system components to cool before touching.
    When the computer is plugged in, the power supply always has voltage applied to the system board even when the unit is turned off. Failure to disconnect the power cord can result in damage to the system.
    Static electricity can damage the electronic components of the computer or optional equipment. Before beginning these procedures, ensure that you are discharged of static electricity by briefly touching a grounded metal object. See the Hardware Reference Guide for more information.
  3. Remove the computer cover or access panel.
  4. Locate the header and jumper labeled JPD1.
    The password jumper is light green so that it can be easily identified. For assistance locating the password jumper and other system board components, see the Illustrated Parts & Service Map (IPSM) for that particular system. The IPSM can be downloaded from http://www.hp.com/support.
  5. Remove the jumper from pins 1 and 2. Place the jumper on pins 2 and 3.
  6. Replace the computer cover or access panel.
  7. Reconnect the external equipment.
  8. Plug in the computer and turn on power. Allow the operating system to start. This clears the current passwords and disables the password features.
  9. To establish new passwords, repeat steps 1 through 4, replace the password jumper on pins 1 and 2, then repeat steps 6 through 8. Establish the new passwords in Computer Setup. Refer to the Computer Setup (F10) Utility Guide for Computer Setup instructions.
Resetting the CMOS Jumper
  1. Turn off the computer and any external devices, and disconnect the power cord from the power outlet. The power must be disconnected from the system to clear CMOS.
  2. Disconnect the keyboard, monitor, and any other external equipment connected to the computer.
      warning:
    Resetting CMOS will restore the computer to factory defaults and will erase any customized information including passwords, asset numbers, and special settings.
  4. Locate the header and jumper labeled JBAT1.
    Be sure you have disconnected the AC power cord from the wall outlet. The CMOS will not clear if the power cord is connected.
    The CMOS jumper is light green so that it can be easily identified. For assistance locating the CMOS jumper and other system board components, see the Illustrated Parts & Service Map (IPSM) for that particular system. The IPSM can be downloaded from http://www.hp.com/support.
  5. Remove the CMOS jumper from pins 1 and 2 and put the jumper on pins 2 and 3. This clears CMOS.
  6. Put the jumper back on pins 1 and 2.
  7. Replace the computer cover or access panel.
  8. Reconnect the external devices.
  9. Plug in the computer and turn on power.
    Use Computer Setup to reset any special system setups along with the date and time.
For instructions on Computer Setup, see the Computer Setup (F10) Utility Guide.
Contacting Customer Support
For help and service, contact an authorized reseller or dealer. To locate a reseller or dealer near you, visit http://www.hp.com.
If you take the computer to an authorized reseller, dealer, or service provider for service, remember to provide the setup and power-on passwords if they are set.
Refer to the number listed in the warranty or in the Support Telephone Numbers guide for technical assistance.
Country: Flag Bulgaria
