    Fix Windows 10 Update Issues
HP Color LaserJet CP3505 Printer Series - Replace the Toner Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Toner cartridge removal
When a print cartridge approaches the end of useful life, the control panel displays a message recommending that you order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing you to replace the cartridge.
The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y).
Replace a print cartridge when the printer control panel displays a REPLACE <COLOR> CARTRIDGE message.
If all of the print cartridges wear out at the same time and you are printing mostly monochrome (black and white), you should change the print mode to MOSTLY BLACK PAGES.
  1. Open the front door.
    Do not place anything on the transfer unit and do not touch the transfer unit, which is located on the inside of the front door.
  2. Remove the used print cartridge from the printer.
  3. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling.
  4. Grasp both sides of the print cartridge and distribute the toner by gently rocking the print cartridge from side to side.
    Do not touch the shutter or the surface of the roller.
  5. Remove the orange shipping locks and the shipping tape attached to the left shipping lock from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations.
  6. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated.
  7. Firmly close the front door.
    After a short time, the control panel should display Ready.
  8. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  9. If you are using a non-HP print cartridge, check the printer control panel for further instructions.
Parts return
