HP Color LaserJet 4700/CP4005 Series Printers - Replace the Tray 2-x Feed Roller
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Tray 2-x pick-up roller replacement
  1. Turn the product off.
  2. Unplug the product from the wall outlet.
  3. Open the tray.
  4. Look inside the paper tray cavity and locate the front roller (feed roller) at the top. Pinch the blue tabs on the left side of the roller (callout 1), and then release the roller to the left.
  5. Discard the roller.
  6. Remove the new front roller from its package.
  7. Slide the front roller onto the spool.
  8. Slide the tray into the product.
  9. Plug the product into the wall outlet, and then turn the product on.
Parts return
