HP SignagePlayer mp8000s - Spare Parts
New model specific parts lists
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website.
System unit
Item Number
Part Description
Spare Part Number
1
Access panel
587455-001
2
Front bezel
587457-001
3
AC adapter, 135 W
592491-001
4
Optical drive rail and cable kit
594219-001
5
Stand
593231-001
6
Bezel blank, Jack black
593230-001
Standard and Optional boards
Item Number
Part Description
Spare Part Number
1
System boards with thermal grease, alcohol pad and CPU socket cover:
System board
635079-001
System board, excludes ES/CS
635080-001
2
Memory modules (PC3-10600, CL9)
1GB, PC3-10600, DDR3-1333-MHz, SODIMM 240-pins, non-ECC, unbuffered memory module
593232-001
2GB, PC3-10600, DDR3-1333-MHz, SODIMM 240-pins, non-ECC, unbuffered memory module
593233-001
4GB, PC3-10600, DDR3-1333-MHz, SODIMM 240-pins, non-ECC, unbuffered memory module
593234-001
3
Other boards:
802.11a/b/g/n WLAN card
502482-001
TV tuner card (includes cable)
582726-001
4
Processors:
Intel Pentium Dual Core Processors with alcohol pad and thermal grease:
E6500, 2.93-GHz, 2MB L2 cache
586748-001
E6300, 2.80-GHz, 2MB L2 cache
580748-001
E5400, 2.7-GHz, 2MB L2 cache
586743-001
E5300, 2.60-GHz, 2MB L2 cache
516900-001
E3300, 2.5-GHz, 1MB L2 cache
585886-001
E3200, 2.5-GHz, 1MB L2 cache
585885-001
Intel Core 2 Quad Processors with alcohol pad and thermal grease:
Q9550S, 2.83-GHz, 12MB L2 cache
593228-001
Q9505S, 2.83-GHz, 6MB L2 cache
593229-001
Q8400S, 2.66-GHz, 4MB L2 cache
593227-001
Intel Core 2 Duo Processors with alcohol pad and thermal grease:
E8600, 3.33-GHz, 6MB L2 cache
497732-001
E8500, 3.16-GHz, 6MB L2 cache
466170-001
E8400, 3.00-GHz, 6MB L2 cache
509554-001
E7600, 3.06-GHz, 3MB L2 cache
573954-001
E7500, 2.93-GHz, 3MB L2 cache
583006-001
Cable and accessory
Item Number
Part Description
Spare Part Number
1
Optical drive cable/connector
499201-001
2
Cable cover
588981-001
3
Adapter, DisplayPort (DP) to DVI
484156-001
4
Adapter, DisplayPort (DP) to VGA
484155-001
Mass storage devices
Item Number
Part Description
Spare Part Number
1
DVD-ROM drive
506466-001
2
DVD±RW and CD-RW Super Multi Double-Layer Combo drive with LightScribe
506468-001
3
500GB, 7200 RPM hard drive, 2.5-inch
590483-001
4
250GB, 7200 RPM hard drive
497730-001
5
160GB, 7200 RPM hard drive
497729-001
6
64GB solid state drive
581057-001
Miscellaneous parts
Item Number
Part Description
Spare Part Number
1
Card reader assembly
593235-001
2
Chassis fan, rear
499202-001
3
Internal speaker
594221-001
4
Heatsink with alcohol pad and factory-applied thermal grease
587456-001
5
Front I/O panel
587458-001
6
Grommet, hard drive
594220-001
7
Chassis fan, front
587459-001
8
USB powered speakers
571536-001
9
Mouse, PS2, optical, jack black
537748-001
10
Mouse, optical, jack black
537749-001
11
Mouse, laser, jack black
570580-001
12
Hood sensor
392417-001
