HP Color LaserJet CM1312 Multifunction Series Printer - Replace the Toner Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Toner cartridge removal
  1. Cartridge E-label
  2. Plastic shield
  3. Imaging Drum
  1. Open the front door.
  2. Pull out the print-cartridge drawer.
  3. Grasp the handle on the old print cartridge and then pull the cartridge straight up to remove it.
  4. Remove the new print cartridge from the packaging.
  5. Remove the orange, plastic shield from the bottom of the new print cartridge.
    Do not touch the imaging drum on the bottom of the print cartridge. Fingerprints on the imaging drum can cause print-quality problems.
  6. Insert the new print cartridge into the product.
  7. Pull the tab on the left side of the print cartridge straight up to completely remove the sealing tape. Discard the sealing tape.
  8. Close the print-cartridge drawer.
  9. Close the front door.
  10. Place the old print cartridge in the box for the new print cartridge. Follow the recycling instructions that are included in the box.
If toner gets on any clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
Parts return
