Removing the Stand in HP Omni 100-5000 Series Desktop PCs
This document applies to HP Omni 100-5000 series desktop computers.
  • Remove any media (CD, DVD, and memory cards) from the computer.
  • Turn off the computer and disconnect all cables. Be sure to disconnect the network cable before disconnecting the power cord.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends that you put down a blanket, towel, or other soft cloth to protect the screen from scratches or other damage.
  • Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. Use an antistatic wrist strap and a conductive foam pad when working on the computer.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the stand
Remove the stand to mount the computer on the wall. Use the following steps to remove the stand:
Step 1
To remove the stand, first remove the hinge cover above the stand.
For instructions to remove the hinge cover, see the HP support document, Removing and Replacing the Back Covers.
Prying off the hinge cover
Step 2
Lift the hinge cover off and away from the computer.
Removing the cover
Step 3
Remove the three screws that fasten the stand to the computer.
These screws for the stand special long screws. Keep them with the stand.
Removing the screws for the stand
Step 4
Slide the stand up.
Sliding the stand up
Step 5
Tilt the stand up and remove it from the computer.
Removing the stand from the computer
Replacing the stand
Use the following steps to replace the stand:
Step 1
Find the hooked tab at the top of the stand.
Finding the hooked tab at the top of the stand
Step 2
Find the slot for the stand inside the computer.
Finding the slot inside the computer
Step 3
To replace the stand, hook the tab into the slot...
Aligning the stand
... and tilt the stand down until the stand is secure.
Sliding the stand into place
Step 4
Replace the three screws that secure the stand to the computer. Use the same three screws that were removed previously.
Replacing the screws for the stand
Step 5
To replace the hinge cover, find the two small tabs on the hinge cover.
Finding the two tabs
Step 6
Find the two slots inside the computer.
Finding the two slots
Step 7
Align the tabs on the hinge cover with the slots on the back of the computer.
Replacing the cover
Step 8
Press down until the cover snaps into place.
Pressing down to snap the cover into place
