HP Officejet Pro 8500A e-All-in-One Printer (A910n) - Printing from Paper Tray 2 in Windows
This document contains steps for loading paper and for changing the print settings to print from Tray 2. To print documents from Tray 2, you must change the print setting to Tray 2. Paper does not automatically pull from Tray 2 when your product is set to the auto (tray) select option.
Tray 2 supports plain paper only. For other paper types, use the main tray.
Printing from Tray 2 in Windows
Follow these steps to load paper and change the print settings to print from Tray 2.
Step one: Load paper
Follow these steps to load paper in Tray 2.
  1. Grasp the underside of Tray 2, and then pull the tray out.
    Figure : Remove Tray 2
    Image: Removing Tray 2
  2. Slide the paper width guides to their outermost positions.
  3. Insert a stack of plain, white paper print-side down in the center of the tray. Make sure the paper aligns with the engraved lines in the tray.
    Load only plain white paper in Tray 2.
  4. Adjust the paper width guides so that they rest against the edges of the paper.
    Figure : Adjust the paper width guides on Tray 2
    Image: Adjusting the paper width guides
  5. Carefully reinsert the tray into the product.
Step two: Change the print settings to print from Tray 2
Choose your operating system, and then follow the steps to change the print settings to print from Tray 2.
