HP Designjet T7100 and T7100 Monochrome Printer Series - Printer specifications
Functional specifications
HP No. 762 ink supplies
T7100
T7100 Mono
Printheads
Yellow, magenta/cyan, gray/dark gray, black/black
Black/black, dark gray
Ink cartridges
Black, yellow, magenta, cyan, gray, dark gray
Black, dark gray
Maintenance cartridge
Non-color-specific
Non-color-specific
Paper sizes
Minimum
Maximum
Width
280 mm
1067 mm
Length
420 mm
91 m
Roll diameter
180 mm
The printer can cope with paper rolls that vary from their nominal width by up to 3 mm in either direction (wider or narrower).
Print resolution (using Windows HP-GL/2 driver)
Print quality
Maximum resolution for photo paper
Rendering resolution
Printing resolution
Best
On
1200×1200
2400×1200 (HP Premium Instant-dry Photo Gloss, HP Premium Instant-dry Photo Satin, HP Universal Instant-dry Photo Gloss, HP Universal Instant-dry Photo Semi-Gloss, Photo Gloss Paper, Photo Semi-Gloss/Satin Paper, Photo Matte Paper)
1200×1200 (other)
Best
Off
600×600
600×1200 (HP Premium Instant-dry Photo Gloss, HP Premium Instant-dry Photo Satin, HP Universal Instant-dry Photo Gloss, HP Universal Instant-dry Photo Semi-Gloss, Photo Gloss Paper, Photo Semi-Gloss/Satin Paper, Photo Matte Paper)
1200×1200 (other)
Normal
n/a
600×600
1200×1200 (other)
Fast
n/a
300×300
600×1200 (plain paper, bright white bond paper, HP Premium Instant-dry Photo Gloss, HP Premium Instant-dry Photo Satin, HP Universal Instant-dry Photo Gloss, HP Universal Instant-dry Photo Semi-Gloss, Photo Gloss Paper, Photo Semi-Gloss/Satin Paper, Photo Matte Paper)
1200×1200 (other)
Margins
Side margins
5 mm
Top margin (leading edge)
5 mm; 11.5 mm for glossy paper
Bottom margin (trailing edge)
5 mm
Mechanical accuracy
±0.1% of the specified vector length or ±0.1 mm (whichever greater) at 23°C (73°F), 50-60% relative humidity, on A0 printing material in Best or Normal mode with HP Matte Film.
Graphic languages supported
HP Designjet T7100 Printer
HP-GL/2, RTL, CALS/G4
HP Designjet T7100ps Printer
HP-GL/2, RTL, CALS/G4, Adobe PostScript level 3, Adobe PDF 1.7, TIFF, JPEG
Physical specifications
Printer physical specifications
Weight (including stand)
187 kg
Width
1970 mm
Depth
690 mm
Height
1370 mm
Memory specifications
T7100 & T7100 Mono memory (DRAM)
1024MB
T7100ps & T7100ps Mono memory (DRAM)
1536MB
Hard disk
160GB
External hard disk accessory
160GB
Power specifications
Printer power specifications
Input voltage
100–127 Vac / 220–240 Vac ±10%, autoranging
Frequency
50–60 Hz
Current
5 A / 3 A
Power consumption
270 W maximum
Environmental specifications
Printer environmental specifications
Relative humidity range for best print quality
20–80%, depending on paper type
Temperature range for best print quality
15 to 30°C, depending on paper type
Temperature range for printing
5 to 40°C
Temperature range when not in operation
–20 to +55°C
Maximum altitude when printing
3000 m
If the printer or ink cartridges are moved from a cold location to a warm and humid location, water from the atmosphere can condensate on the printer parts and cartridges and can result in ink leaks and printer errors. In this case, HP recommends that you wait at least 3 hours before turning on the printer or installing the ink cartridges, to allow the condensate to evaporate.
Acoustic specifications
Printer acoustic specifications
Idle sound power
≤ 5.8 B (A)
Operating sound power
≤ 7.0 B (A)
Idle sound pressure
≤ 38 dB (A)
Operating sound pressure
≤ 53 dB (A)
