HP Compaq LA2206x 21.5-inch WLED Backlit LCD Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked w/stand
  • (33.33 to 43.87) x 51.80 x 22.73 cm ((13.2 to 17.27) x 20.39 x 8.95 in)
Unpacked w/o stand (head only)
  • 31.5 x 51.8 x 4.75 cm (12.40 x 20.39 x 1.87 in)
Packaged
  • 15.4 x 58.1 x 46.8 cm (6.06 x 22.87 x 18.43 in)
Head only
  • 3.8 kg (8.4 lb)
Unpacked
  • 6.1 kg (13.4 lb)
Packaged
  • 8.3 kg (18.4 lb)
Tilt range
-5° to +30°
Swivel range
Yes (+/-360°)
Height adjustable
Yes from 0 to 13.0 cm (0 to 5.1 in)
Detachable stand
Detachable, ships attached
Panel specifications
Specification
Type
TN (Twisted Nematic) WLED Backlit LCD
54.61 cm (21.5 in) widescreen
Screen opening (W x H)
47.66 x 26.81 cm (18.76 x 10.56 in)
Resolution
1920 x 1080 @ 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
1,000,000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.0248 cm
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut
68%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
  • Menu
  • OK
  • Power
Languages
  • English
  • French
  • German
  • Italian
  • Dutch
  • Spanish
  • Japanese
  • Portuguese
  • Traditional Chinese
  • Simplified Chinese
User controls
  • Brightness
  • Contrast
  • Positioning
  • Color temperature (warm, standard, cool, custom)
  • Image control (clock, clock phase, scaling, sharpness, DCR)
  • Monitor management
  • Source control
  • Factory reset
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz (VGA); 165 MHz (DVI and DisplayPort)
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
Warm (6500K)
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog), DVI-D and DisplayPort w/HDCP, USB
Input impedance
75 Ohms (VGA)
Sync input
TTL separate synch
Video/other cable
(1) DVI-D cable, (1) VGA cable, (1) USB cable
Video cable length
1.8 m (5.9 ft)
Power specifications
Specification
Input power
100 to 240 V ac, 50/60 Hz
Typical power consumption
28 W
Maximum
36 W
Power saving
< 0.5 W standby; < 0.5 W Off
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C (101.66°F) max wet-bulb
Operating altitude
+0 to 5,000 m (16,404 ft)
Non-operating altitude
+0 to 12,192 m (40,000 ft)
