    Looking for Site Help?
HP Deskjet Ink Advantage 2060 Printers - Description of the Control Panel
This document is for HP Deskjet Ink Advantage 2060 All-in-One printers.
    Figure : Graphic - The control panel of the HP Deskjet Ink Advantage 2010 Printer (K010)
  1. 1 On: Turns the product on or off. When the product is off, a minimal amount of power is still used. To completely remove power, turn off the product, then unplug the power cord.
  2. 2 Cancel: Stops the current operation.
  3. 3 Resume: Instructs the HP Printer to continue after a problem is solved.
  4. 4 Printer display: Displays printer status and current estimated ink levels.
  5. 5 Attention light: Signals if there is an error, indicating a user action is required.
  6. 6 Printer icon: Signals a carriage stall, the carriage door should be closed, or the output tray should be opened.
  7. 7 Output tray icon: Signals that the output tray should be opened.
  8. 8 Ink drop icon: Signals a problem with one or both cartridges.
  9. 9 Ink gauge icons: Displays estimated current ink levels and signals when there are cartridge problems.Ink level warnings and indicators provide estimates for planning purposes only. When you receive a low-ink warning message, consider having a replacement cartridge available to avoid possible printing delays. You do not have to replace the cartridges until the print quality is unacceptable.
  10. 10 Paper icon: Signals printer is out of paper or there is a paper jam.
Country: Flag Bulgaria
