HP Designjet T2300 eMFP Product Series - Remove an ink cartridge
There are two occasions when you need to remove an ink cartridge.
  • The ink cartridge is very low and you want to replace it with a full cartridge for unattended printing (you can use up the remaining ink in the first cartridge at a more convenient time).
  • The ink cartridge is empty or faulty, and you must replace it to continue printing.
Do not try to remove an ink cartridge while printing.
Remove an ink cartridge only if you are ready to insert another one.
Make sure the product wheels are locked (the brake lever is pressed down) to prevent the product from moving.
When a cartridge runs out of ink, the current job is not automatically cancelled: unless you cancel it manually, it will resume printing when the empty cartridge has been replaced. If there is a delay in replacing the cartridge, you may see some banding on the print.
  1. From the front panel, press , then , then Replace ink cartridges.
    Alternatively, press , then , then Ink > Replace ink cartridges.
  2. Open the ink cartridge cover on the left-hand side of the product.
    Figure : Opening the cartridge cover
  3. Grip the cartridge you wish to remove.
  4. Pull the cartridge straight up.
    Figure : Removing an ink cartridge
    Avoid touching the end of the cartridge that is inserted into the product, as there may be ink on the connection.
    Avoid storing partially used ink cartridges.
    Figure : Ink cartridge removed
  5. The front-panel display identifies the missing ink cartridge.
