HP Designjet T2300 eMFP Product Series - Print from a USB flash drive
  1. Insert a USB flash drive containing one or more TIFF, JPEG, HP-GL/2, RTL, PDF or PostScript files into one of the product's USB ports.
    To print PDF or PostScript files, the T2300 PS is required.
    The use of USB flash drives with your product may be disabled in the Embedded Web Server (Setup > Security > Disable USB drives or Disable USB printing).
  2. At the front panel, go to the home screen and press .
  3. Press .
  4. Select the file to be printed. Files that can be printed are indicated with ; files that cannot be printed are indicated with . You can press folders to browse their contents.
  5. The default print settings are displayed. If you want to change them, press Settings. The following settings are available:
    • Size allows you to resize the print in two different ways: to a percentage of its original size, or to fit a particular paper size. The default is 100% (its original size).
    • Color allows you to choose color or grayscale printing.
    • Print quality allows you to set the print quality to Best, Normal or Fast.
    • Roll allows you to specify printing on roll 1 or roll 2, or you can choose Save paper, which automatically chooses the narrowest roll on which the print will fit.
    • Rotation allows you to rotate the print by any multiple of 90°, or you can choose Automatic, which rotates the print automatically if that will save paper.
    If you change the settings in this way, the changed settings apply to the current job but are not saved permanently. You can change the default settings from the main menu: press , then , then Print from USB preferences.
  6. To display a preview of the printed job on the front panel, press .
    When the preview is displayed, you can press it to zoom in on it. Press it again to zoom out.
  7. When you are satisfied with the print settings, press Start.
  8. If two rolls are loaded, you can choose to print on either roll, or you can let the printer choose automatically.
    The printer will automatically rotate the image by 90° if it can save paper by doing so.
  9. After printing, you can choose to print another file or go to the job queue. If you print another file immediately without returning to the home screen, the temporary settings used for the previous file are used again.
