HP G62-b70SQ Notebook PC Product Specifications
Product Name
G62-b70SQ
Product Number
XF251EA
2.26 GHz Intel Core i3-350M Processor
Microprocessor Cache
Level 3 cache 3 MB
Memory
3 GB DDR3 (1 x 1024 MB + 1 x 2048 MB)
Memory Max
Supports up to 4 GB DDR3 memory
Video Graphics
ATI Mobility Radeon HD 5470 Graphics (switchable)
Video Memory
up to 1799 MB total graphics memory with 512 MB DDR3 dedicated
39.6 cm (15.6") diagonal High-Definition LED HP BrightView Display (1366 x 768)
Hard Drive
500 GB SATA Hard Disk Drive 7200 rpm
Multimedia Drive
SATA optical drive: LightScribe SuperMulti DVD±R/RW with Double Layer Support
Network Card
Integrated 10/100BASE-T Ethernet LAN
Wireless Connectivity
802.11 b/g/n
Sound
Altec Lansing speakers
Keyboard
Full size keyboard with One touch launch keys and Action keys
Pointing Device
Touch Pad with On/Off button and 2-way Scroll pad support
PC Card Slots
5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro or xD Picture cards
External Ports
  • 1 VGA port
  • 1 stereo headphone-out
  • 1 microphone-in
  • 3 USB 2.0 ports
  • 1 RJ45 ethernet port
Dimensions
24.6 cm (L) x 37.4 cm (W) x 3.18 cm (min H) / 3.68 cm (max H)
Starting at 2.20 kg
Power
90 W AC Power Adapter
6-cell Lithium-Ion (Li-Ion) battery
What's In The Box
Webcam with Integrated Microphone (VGA)
Operating System:
Linux SuSe SLED11
