HP Designjet Z6200 Photo Printer Series - Load a roll into the printer
To start this procedure, you need to have a roll loaded on the spindle.
  1. At the printer's front panel, select the icon, and then select Paper load > Load roll.
    Figure : Front panel load roll message
    Alternatively, you can start loading paper without using the front panel, by feeding paper in or lifting the pinch lever when there is no paper loaded.
    If you lift the pinch lever, you will need to align the paper manually; follow the instructions on the front panel.
  2. If printing paper info is disabled, the front panel asks you to select the paper type.
  3. The front panel asks you to feed paper. When the printer detects the paper, paper checks will begin.
  4. If the paper that you are using has a paper-data barcode printed on the leading edge of the roll, and printing paper info is enabled, the printer automatically reads the information. If printing paper info is disabled, the barcode is ignored.
    Figure : Paper-data barcode
    If printing paper info is enabled and no barcode is detected on the roll that is being loaded, the front panel asks you to enter the paper type and the length of the roll you are loading. Select the paper category and paper type of the roll.
    Figure : Paper categories
    Select the length of the roll.
    Figure : Paper lengths
  5. If some of the paper checks failed, the front panel explains the problem and helps you to load paper successfully.
  6. If you have a take-up reel (a standard feature on the 1.5m printer and an optional accessory on the 1.1m printer), a message will appear on the front panel asking if you want to load paper onto the take-up reel. If you select No (or if you do not have a take-up reel) the front panel displays the Ready message and the printer is ready to print. If you select Yes, a message will appear on the front panel asking if you want to load the take-up reel now or during printing.
    Figure : load the take-up reel now or during printing
    • If you want to load the take-up reel now, select Load take-up reel now, read through the introductory text in the section Use the take-up reel, and then continue to step 3 of the procedure.
    • If you want to load the take-up reel during printing, select Load it during printing, read through the introductory text in the section Use the take-up reel, and then continue to step 3 of the procedure.
      Familiarize yourself with the procedural steps, because loading the take-up reel while printing requires you to complete the procedure while the printer is feeding and printing paper. Loading the take-up reel during printing saves approximately 1 m of paper.
During the initial printer setup, printhead alignment and color calibration are performed automatically after the roll is loaded into the printer.
Country: Flag Bulgaria
