    Looking for Site Help?
HP Deskjet 3000 Printers - Troubleshooting printer setup with a firewall or anti-virus protection
This document is for HP Deskjet 3000 (J310a, J310c) printers.
The following best practices can solve most issues related to firewalls and anti-virus software. For specific information about your particular software settings, contact the software manufacturer.
Best practices for firewalls or anti-virus software
  • Keep your security software up to date. Many security software vendors provide updates that correct known issues and provide the latest defenses against new security threats.
  • If your firewall or anti-virus software has High, Medium, or Low security settings, use the Medium setting when your computer is connected to your network.
  • If you changed any firewall or anti-virus settings, try going back to the default setting.
  • If your software has a setting called Trusted zone, use this setting when your computer is connected to your network.
  • If your software has a Do not show alert messages setting, make sure it is not turned on. When you install the HP software and use the printer, you may see alert messages from your firewall or anti-virus software that give you options to Allow, Permit, or Unblock the printer software. You should allow any HP software that causes an alert. Also, if the alert has a Remember this action or Create a rule for this option, select it. This is how the firewall or anti-virus software learns what can be trusted on your network.
  • Do not have more than one firewall enabled at the same time on your computer. For example, do not enable the Windows firewall provided by the operating system and a third-party firewall at the same time. Having more than one firewall enabled at the same time will not make you computer any safer and may cause problems.
For more information, visit the HP Wireless Printing Center online:
If you were unable to install your HP printer successfully, you may need to disable startup services and/or your firewall temporarily. Windows allows many programs and processes to run immediately upon startup. These programs and your firewall may be preventing you from installing the HP software or getting the printer on the network. These directions explain how to disable these programs and processes during printer setup.
Step 1: Disable startup services
  1. Bookmark this page in your Web browser so you can return to it after you restart your computer in a later step.
    To bookmark a page, click Favorites or Bookmarks in your Web browser, and then click Add to Favorites or Bookmark This Page.
    To return to this page after the restart, open your Web browser, click the Favorites or Bookmarks menu, and then click the name of this Web page. When the page opens, scroll down to view the rest of these instructions.
  2. Open the System Configuration Utility dialog box:
    Windows 7
    1. On the Windows taskbar, click .
      Type msconfig in the Search programs and files dialog box, and then press Enter.
    Windows Vista
    1. On the Windows taskbar, click , and then click Run.
      Type msconfig in the Run dialog box, and then click OK.
    Windows XP
    1. On the Windows taskbar, click Start, and then click Run.
  3. Check to see if Normal Startup or Selective Startup is currently selected. If Normal Startup is selected, follow the indicated steps, below. If Selective Startup is selected, follow those steps instead.
    Follow the appropriate instructions for your startup type. You only need to follow one set of instructions, not both.
    To disable a Normal Startup
    1. Select Selective Startup, and then clear the Load Startup Items check box.
      Click the Services tab, and then select the Hide All Microsoft Services check box at the bottom of the screen.
      Click Disable All.
    To disable a Selective Startup
    1. Click the Startup tab and make a list of the items that are selected.
      You will need this list to reset your computer startup items later.
      Click the General tab, and then clear the Load Startup Items check box.
      Make a list of the items that are selected.
      Click Disable All.
  4. Click Apply, and then click OK.
    A new window displays. Click Restart to continue.
  5. Upon restarting your computer, the System Configuration Utility window displays. Select the Don't show this message... check box, and then click OK.
Step 2: Temporarily disable or configure the firewall or anti-virus software on your computer
  1. Right-click the firewall icon on the task bar (near the date and time on the computer), and click Stop or Disable.
    If there is no stop option, open the firewall software and select the option to stop or disable it. The firewall icon may change to show that it is disabled.
  2. Restart the computer.
  3. Try using your printer again.
  4. If the printer works when your firewall is disabled, you should configure the firewall to allow a connection with the printer. For more information, visit the HP Wireless Printing Center online:
Step 3: Reinstall the HP software
  1. We recommend that you download the latest version of the software for your product from the HP Web site:
    1. Type the name of the printer in the search box (for example, type HP Deskjet 3000 J310 series).
      Select the appropriate version of Windows to view the download and CD ordering options.
  2. Reinstall the HP software by running the new install program that you downloaded or re-inserting the CD that came with your printer.
  3. Accept or allow any firewall pop-up messages that appear during software installation.
Step 4: Enable startup services
  1. Open the System Configuration Utility dialog box:
    Windows 7
    Windows Vista
    Windows XP
  2. If you disabled a Normal Startup, follow the indicated steps, below. If you disabled a Selective Startup, follow those steps instead.
    To enable a Normal Startup
    1. Select Normal Startup.
    To enable a Selective Startup
    1. Click the Startup tab, and then select every item from the list you made in step A.
      On the Services tab, select every item from the list you made in step A.
  3. Click Apply, and then click OK.
  4. If you disabled your firewall or anti-virus software, follow the instructions in the next step to enable it again.
Step 5: Enable the firewall or anti-virus software on your computer
  1. Right-click the firewall icon on the task bar (near the date and time on the computer), and click Start or Enable.
    If there is no start option, open the firewall software and select the option to start or enable it. The firewall icon may change to show that it is enabled.
    If the printer works when your firewall is disabled, it will stop working when you enable it again, unless you configure the firewall to allow a connection with the printer. For more information, visit the HP Wireless Printing Center online:
For further assistance
Hewlett-Packard provides various support options to help you use your printer or solve a problem.
HP Support Web Site: Support and troubleshooting information for your specific product is available and is the best source for current product information. If you need contact information, click Contact HP to view your assisted support options.
If prompted, choose your country/region. Select the support and troubleshooting option, and then type your product name and number in the field provided.
HP Support Forums: Connect with HP users to get insights, tips, and answers to questions about your product.
HP Wireless Printing Center: Learn more about wireless printing, troubleshoot wireless problems, and set up and configure your network.
HP Print and Scan Doctor:
HP provides a free tool called HP Print and Scan Doctor to diagnose and resolve printing problems. Download and run HP Print and Scan Doctor  to quickly and automatically perform several troubleshooting tasks known to resolve this issue. When this link is clicked, HP Print and Scan Doctor is downloaded using your Internet browser's download capabilities.
Some support options may not be available for every product, country/region, or language.
Country: Flag Bulgaria
