HP EliteBook 8540p Notebook PC - Removing and Replacing the Expansion Memory Board
This document is provided to assist in removing and replacing the expansion memory board for the HP EliteBook 8540p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the expansion memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
2GB, PC3-10600, shared DDR3-1333 MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598856-001 (Modified)
Yes
4GB, PC3-10600, shared DDR3-1333 MHz SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
599092-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the expansion memory board, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Expansion memory board from the menu on the upper left hand side of the screen.
Click here to view the expansion memory board removal video (right-click on the link to open in a new window/tab).
Expansion memory board removal
  2. Loosen the two captive P1 Phillips-head screws marked with a memory icon that secure the memory cover to the bottom of the notebook.
  3. Lift the memory cover and remove it.
  4.   caution:
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
    Push both arms outward simultaneously to release the memory board to the spring tension position.
  5. Grasp the memory board by the edges and pull gently to remove it.
  6. Place the memory board in a static dissipative bag.
Expansion memory board replacement
  1.   caution:
    Grasp the memory board by the edges and remove it from the static dissipative bag.
  2. Align the notch in the memory board with the key in the memory board slot on the system board.
  3. At an angle, gently insert the memory board into its slot on the system board.
  4. Press the memory board down to latch the arms.
  5. Toe the memory cover into the base enclosure and lower it into position.
  6. Tighten the two captive P1 Phillips-head screws marked with a memory icon that secure the memory cover to the bottom of the notebook.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
