    Fix Windows 10 Update Issues
HP ProBook 6540b Notebook PC - Removing and Replacing Switch Cover
This document is provided to assist in removing and replacing the switch cover for the HP ProBook 6540b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the switch cover that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Cover switch 15.6
593860-001 (Modified)
No
Cover switch 14.0
593861-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the switch cover, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Switch cover from the menu on the upper left hand side of the screen.
Click here to view the switch cover removal video (right-click on the link to open in a new window/tab).
Switch cover removal
  2. On the bottom of the notebook, remove the three 3 mm P1 Phillips-head screws marked with a triangle inside the battery bay.
  3. Turn the notebook right side up and open the display panel fully.
  4. Using minimal force, lift the locking bar up on the button board ZIF connector and disconnect the button board ribbon cable from the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  5. Moving from left to right, pull up on the rear edge of the switch cover to detach it from the base enclosure.
  6. Remove the switch cover from the base enclosure.
Switch cover replacement
  1. Toe the alignment tabs on the front edge of the switch cover into the slots on the top cover and lower the switch cover into position.
    Make sure that the button board ribbon cable is free from being pinched between the switch cover and top cover.
  2. Press along the entire length of the switch cover to snap it into place.
  3. Insert the button board ribbon cable into the button board ZIF connector on the system board.
  4. Push the locking bar down to lock the button board ZIF connector.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the three 3 mm P1 Phillips-head screws marked with a triangle inside the battery bay.
