The Attention Light Blinks (Paper Jam) for HP LaserJet Pro CP1025 and CP1025nw Color Printers
Issue
The Attention light () on the control panel blinks. The Ready light might also blink. Paper is jammed in the product.
Paper jams can occur in multiple locations in the product.
    Figure : Jam locations
    Illustration: Paper jam locations on the product.
  1. Output tray
  2. Rear door
  3. Input tray
  IMPORTANT: You must follow these solutions in the order presented to resolve the issue.
Solution one: Clear the jam, reload paper, and then print a self-test report
Loose toner might remain in the product after a jam. This problem typically resolves itself after the product prints a few sheets.
Paper jams might result in loose toner on the page. If you get any toner on your clothes, wash them in cold water. Hot water permanently sets the toner into the fabric.
Do not use sharp objects, such as tweezers or needle-nose pliers, to remove jams. Damage caused by sharp objects is not covered by the warranty.
When you remove jammed paper, pull it straight out of the product. Pulling jammed paper out at an angle can damage the product.
Step one: Remove any loose paper first
Remove all loose paper from the input tray and the output tray.
Do not try to remove jammed paper at this stage.
Step two: Clear the jam from the output tray
Follow these steps to clear the paper jam.
  1. With both hands, grasp the jammed paper where it is most visible, including the middle, and then carefully pull the paper straight out of the output tray.
    Figure : Clear the jam from the output tray
    Image: Clear the jam from the output tray.
Step three: Clear the jam from the back of the product
  1. Turn the product around, and then open the rear door.
    Figure : Open the rear door
    Image: Open the rear door.
  2. With both hands, grasp the jammed paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
    Figure : Clear the jam from the rear of the product
    Image: Clear the jam from the rear of the product.
  3. Close the rear door.
    Figure : Close the rear door
    Image: Close the rear door.
Step four: Clear the jam from the input tray
  1. With both hands, grasp the jammed paper where it is most visible, and then carefully pull the paper straight out of the input tray.
    Figure : Clear the jam from the input tray
    Image: Clear the jam from the input tray.
Step five: Reset the product
Open and close the print cartridge door to reset the product.
Figure : Open and close the print cartridge door
Image: Open and close the print cartridge door.
Step six: Reload plain paper
  1. Slide the paper length and width guides to their outermost positions.
  2. Load plain white paper in the input tray. Slide the paper forward until it stops.
    Figure : Load plain white paper
    Image: Load plain white paper.
    Do not overload the tray. Make sure that the stack of paper fits within the tray and is no higher than the top of the guides.
  3. Slide the paper length and width guides inward until they stop at the edges of the paper.
    Figure : Slide paper guides inward
    Image: Slide paper guides inward.
Step seven: Print a self-test report
Printing a self-test report verifies if the hardware functions correctly.
  1. Make sure that the product is idle and the Ready light () is on.
  2. Press and hold the Resume button () for two to three seconds, and then release the button. The product prints a self-test report and a supplies status page.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Solution two: Check for any torn paper, debris, or foreign objects in the cartridge area
Check for and remove any torn pieces of paper, debris, or foreign objects that are accessible from the print cartridge area.
You need a flashlight to complete some of these steps.
Figure : Flashlight
Flashlight
  1. Close the print cartridge and rear doors, if they are not already closed.
  2. On the control panel, press the Print Cartridge button that corresponds to the print cartridge you want to replace.
    The printer makes noises while the toner cartridge carousel rotates.
    Figure : Press the print cartridge button
    Press the print cartridge button.
  3. Wait until the Print Cartridge light stops flashing and the rotation sounds stop before you proceed to the next step.
  4. Open the print cartridge door.
    Figure : Open the print cartridge door
  5. Grasp the handle on the print cartridge, and then pull the print cartridge straight out to remove it. Set the print cartridge aside.
    Figure : Remove the print cartridge
    Remove a print cartridge.
  6. Turn off the printer, and then disconnect the power cord from the wall socket or power strip.
      warning:
    You must disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  7. Use a flashlight to thoroughly check for any torn pieces of paper, debris, or foreign objects that might remain inside the printer. If any torn pieces of paper or foreign objects remain inside the printer, more jams are likely to occur.
  8. Grasp the print cartridge by the center handle, and then insert the print cartridge into the correct slot. Make sure the color label on the print cartridge matches the color label in the carousel slot.
    Figure : Insert the print cartridge into the correct slot
    Insert the print cartridge  into the correct slot.
  9. Reconnect the power cord to the wall outlet or power strip, and then turn on the printer.
  10. Try to print again.
If the error persists, continue to the next step to reset the printer.
Solution three: Perform a power reset, check the print settings, and print a self-test report
Follow these steps to perform a power reset, check the print settings, and print a self-test report.
Video of resolving paper pick issues
The following video demonstrates what to do when your printer does not pick up or feed paper from the input tray.
This video shows an HP LaserJet Pro CP1025nw Color printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Step one: Perform a power reset
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet.
  3. Wait at least 15 seconds.
  4. Plug the power cord back into the wall outlet.
  5. Reconnect the power cord to the printer.
  6. Turn the printer on.
Step two: Check the print settings
  1. From the File menu in the software program, click Print.
  2. In the Print dialog box, click Properties.
  3. Check the settings on the Paper/Quality tab, change them if necessary, and then click OK.
  4. Try printing again.
Step three: Print a self-test report
Solution four: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
