    Fix Windows 10 Update Issues
    Are you working from home?
HP Single-Function and Multi-Function Printers - 'Fatal Error during installation. The installer has insufficient privileges to modify this file C:\Windows…flash[xx].ocx' Message Displays during Installation in Windows
Issue
The error message 'Fatal Error during installation. The installer has insufficient privileges to modify this file C:\Windows\System32\Macromed\Flash\flashxx.ocx' displays during installation of the HP software in Windows.
Solution
First, make sure that your computer is connected to the internet. Then, choose your operating system.
