HP LaserJet M2727 MFP Series Printer - Configure "Scan To" on Windows 7 32-bit and 64-bit Operating System
Before scanning from the control panel of the MFP can be performed, it must be configured in the HP LaserJet Scan software.
The Full Solution software for HP LaserJet M2727MFP Series printer must be installed to enable "Scan To" functionality.
This Full Solution software download is specific to Microsoft Windows 7 only. Also, this is not a software upgrade for versions of the software for Microsoft Windows XP or Vista.
Details
Use the following instructions to configure "Scan To" options:
  1. Select Scan.exe from Start, HP, HPM2727, Scan
  2. On HP LaserJet Scan screen, select Setup.
  3. Select forth option (Change the destination that show up on the all-in-one control panel, when pressed the Scan To button) on Scan Setup Options and select Next.
  4. Check the box for Allow me to scan be pressing the Scan To option on Setup the Scan To list for the All-in-one. This will provide all default destinations under Available Destinations on this PC.
  5. Use >> to move all default destination to The destination currently on the all-in-one.
  6. Select Update option to add these destinations.
    Scan from HP LaserJet M2727MFP series printer by using HP LaserJet all-in-one product control panel by performing the following:
    From the HP LaserJet M2727MFP series printer control panel:
    1. Press the Scan To button.
    2. Use the < or > buttons to make a selection from the destination listed,
    3. Press Enter.
