HP ProBook 6440b Notebook PC - Removing and Replacing Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP ProBook 6440b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
500GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket
583246-001 (Modified)
Yes
320GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket
583245-001 (Modified)
Yes
250GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket
583244-001 (Modified)
Yes
160GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket
583243-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Lift the hard disk drive cover and remove it.
  4. Loosen the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  5. Grasp the Mylar tab that is attached to the hard disk drive bracket and slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the primary storage drive bay.
  7. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Toe the hard disk drive into the primary storage drive bay and align it with the system board connector.
  3. Press the hard disk drive into the connector on the system board until it is firmly seated.
  4. Tighten the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  5. Toe the hard disk drive cover into the base enclosure and lower it into position.
  6. Tighten the two captive P1 Phillips-head screws.
Parts return
