This document is provided to assist in removing and replacing the battery for the HP ProBook 6545b Notebook PC.
- ${title}
- ${title}
- ${title}
- ${title}
HP ProBook 6545b Notebook PC - Removing and Replacing Battery
Minimum skill level
Parts required
note:Part numbers are subject to change.
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 9-cell lithium-ion (Li-Ion), 2.8 Ah, 93 Wh
586031-001 (Modified)
Yes
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 55 Wh
482962-001 (Modified)
Yes
note:For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labelled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Slide the battery release latch toward the outside of the notebook to eject the battery.
Slide the battery out of the battery bay.
Battery replacement
Slide the battery into the battery bay until it is properly seated and the release latch clicks.
Parts return
If your part requires return then click on the appropriate link below:
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
