HP ProBook 6545b Notebook PC - Removing and Replacing Primary Memory Board
This document is provided to assist in removing and replacing the primary memory board for the HP ProBook 6545b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the primary memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4GB, 800 MHz, PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598855-001 (Modified)
Yes
2GB, 800 MHz, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598858-001 (Modified)
Yes
Memory module SODIMM 1GB
583240-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the primary memory board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Primary memory board from the menu on the upper left hand side of the screen.
Click here to view the primary memory board removal video (right-click on the link to open in a new window/tab).
Primary memory board removal
  2. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  3. Grasp the memory board by the edges and pull gently to remove it.
  4. Place the memory board in a static dissipative bag.
Primary memory board replacement
  1. Grasp the memory board by the edges and remove it from the static dissipative bag.
  2. Align the notch in the memory board with the key in the memory board slot on the system board.
  3. At an angle, gently insert the memory board into its slot on the system board.
  4. Press the memory board down to latch the arms.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
