This document is provided to assist in removing and replacing the RTC battery for the HP ProBook 6545b Notebook PC.
- ${title}
- ${title}
- ${title}
- ${title}
HP ProBook 6545b Notebook PC - Removing and Replacing RTC Battery
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
note:Part numbers are subject to change.
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
RTC Battery
583289-001 (Modified)
No
note:For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labelled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the RTC battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select RTC battery from the menu on the upper left hand side of the screen.
Click here to view the RTC battery removal video (right-click on the link to open in a new window/tab).
RTC battery removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Remove the battery. Click here for instructions on how to remove battery.
Remove the keyboard. Click here for instructions on how to remove keyboard.
Disconnect the RTC battery cable from its connector on the system board.
Using a non-metallic, flat bladed tool, gently pry the RTC battery out of its cradle on the top cover and remove it from the base enclosure.
RTC battery replacement
Place the RTC battery into its cradle on the top cover.
Press down on the RTC battery to adhere it to the top cover.
Connect the RTC battery cable into its connector on the system board.
Replace the keyboard. Click here for instructions on how to replace keyboard.
Replace the battery. Click here for instructions on how to replace battery.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
