Compaq 615 Notebook PC - Removing and Replacing Speaker
This document is provided to assist in removing and replacing the speaker for the Compaq 615 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the speaker that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Speaker assembly
538453-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the speaker, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Speaker from the menu on the upper left hand side of the screen.
Click here to view the speaker removal video (right-click on the link to open in a new window/tab).
Speaker removal
  2. Disconnect the speaker cable from the system board.
  3. Remove the tape that secures the speaker cable to the top cover.
  4. Remove the speaker cable from its routing tabs on the top cover.
  5. Remove the two 3 mm P00 Phillips-head screws that secure the speaker to the top cover.
  6. Lift and remove the speaker.
Speaker replacement
  1. Place the speaker into position on the base enclosure.
  2. Replace the two 3 mm P00 Phillips-head screws that secure the speaker to the top cover.
  3. Route the speaker cable through the two routing tabs on the top cover.
  4. Replace the tape that secures the speaker cable to the top cover.
  5. Connect the speaker cable to the system board.
