HP 2310ti 23-inch Multi-touch LCD Monitor - Identifying Components
Front panel controls
Item number
Control button
1
Menu
Opens, selects or exits the on-screen display (OSD) menu.
2
Volume/Minus
If the OSD menu is inactive, press to open the Volume adjustment OSD sub-menu. If the OSD menu is on, press to navigate down through the OSD menu and decrease adjustment levels.
3
Source/Plus
If the OSD menu is inactive, press to activate the source button that chooses the video signal input. If the OSD menu is on, press to navigate up through the OSD menu and increase adjustment levels.
4
Auto/OK
If the OSD menu is inactive, press to activate the auto adjustment feature to optimize the screen image. If the OSD menu is on, press to select the highlighted menu item.
5
Power
Turns the monitor on or off as long as the master power switch on the rear panel is on.
6
Power LED
  • AquaWhite = Fully powered
  • Amber = Sleep mode
  • Flashing Amber = Sleep Timer mode
Country: Flag Bulgaria
