    Apache Log4j Update
HP LaserJet 3050/3052/3055/3390/3392 All-in-One Printer - Receive Fax to PC on Windows 7 32-Bit Operating System
HP LaserJet 3050/3052/3055/3390/3392 All-in-One (AIO) printers: Receive Fax to PC on Windows 7 32-bit operating system.
The Hewlett-Packard LaserJet 3050/3052/3055/3390/3392 AIO product CD for Windows Vista 32 bit (and the Vista 32 bit Full Solution Software bundle on the HP website) can be run in compatibility mode in Windows 7 for product software functionality.
Products are supported in Windows 7 32-bit operating systems only.
Details
Incoming Faxes can be received to the computer desktop by enabling Fax Receive Mode in HP ToolboxFX. Perform the following steps to receive faxes to the computer:
  1. Click the Fax tab in HP ToolboxFX.
  2. In the Fax Receive Mode section, click Receive faxes to this computer.
  3. If notification of a received fax is required, select Display a message when a fax is received to this computer.
  4. Click Apply.
Fax receive notification:
Perform the below steps to view Faxes received by the computer in HP ToolboxFX:
  2. Click Fax Receive Log.
  3. Click the View link next to the entry of the Fax to be viewed.
    The Fax viewer page opens in a new browser window. The page shows thumbnail images of all pages of the fax. Click the Printable Version button on the Fax viewer page. A PDF version of the Fax opens in a browser window. The full-size images of the Fax pages can now be viewed.
  • Adobe Acrobat Reader is required to view most faxes.
  • The Fax entries in the Fax Receive Log can be sorted by Date/Time Received, Job #, Fax number, Pages, and Result.
  • All Faxes will be received to the computer until this feature is turned Off.
  • Only one computer at a time can have the Receive faxes to this computer option selected.
  • The Receive faxes to this computer option can be turned Off in HP ToolboxFX on the computer where the option was turned On. The option also must be turned Off at the device control panel.
  • Faxes that are received when the computer is not connected to the All-in-One device and stored on the device until the computer is connected will be sent to the computer at that time.
  • When the All-in-One memory becomes full, it no longer answers incoming Fax calls.
