HP ProBook 4310s Notebook PC - Removing and Replacing the Memory Boards
This document is provided to assist in removing and replacing the memory board for the HP ProBook 4310s Notebook PC.
Minimum skill level
Tools required
  • P1 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1GB, PC3-10600 Shared DDR3-1333 MHz SDRAM Small Outline Dual In-Line Memory Module
598859-001 (Modified)
Yes
2GB, PC3-10600 DDR3 1333 MHz, SDRAM Small Outline Dual In-Line Memory Module
598856-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory Boards from the menu on the upper left hand side of the screen.
Click here to view the memory board removal video (right-click on the link to open in a new window/tab).
Memory board removal
  2. Loosen the two captive P1 Phillips-head screws that secure the wireless and memory cover to the bottom of the notebook.
  3. Lift the wireless and memory cover and remove it.
    The primary and expansion memory slots are both located under the memory cover. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory board is installed, it must be removed before the primary memory board can be removed.
  4. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the memory board by the edges and pull gently to remove it.
  6. Place the memory board in a static dissipative bag.
Memory board replacement
  1. Remove the memory board from the static dissipative bag.
  2. Align the notch in the memory board with the key in the board receptacle.
  3. Grasp the memory board by the edges and push gently to replace it.
  4. Press the memory board down to latch the arms.
  5. Toe the wireless and memory cover into the base enclosure.
  6. Tighten the two captive P1 Phillips-head screws that secure the wireless and memory cover to the bottom of the notebook.
Parts return
