note:Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
caution:Hold the cartridge at each end to prevent damage to the cartridge.
caution:If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
note:After you turn on the product, an 'Install black cartridge' message might display on the product control panel. If you receive this message, follow these steps to resolve the issue.
