    Fix Windows 10 Update Issues
HP LaserJet M5025 and M5035 Multifunction Printer Series - Replace the Toner Cartridges
Summary of instructions
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/so/sml). Select Printers and Multifunction under the Product category, Select HP LaserJet MFP and All-in-one Products under the Product family, and then select the printer model under the product series category.
Toner cartridge replacement
  1. Open the print cartridge door.
  2. Grasp the print cartridge and pull it up and out of the device.
  3. Remove the packing tape from the toner cartridge.
  4. Insert the new print cartridge into the device.
  5. Close the print cartridge door.
