HP Designjet T770 and T1200 Printer Series - Control access to the printer
From the Embedded Web Server, you can select Setup > Security to control access to the printer in various ways:
  • Specify separate administrator and guest passwords to control access to the Embedded Web Server
  • Enable or disable Ethernet and USB connections to the printer
  • Enable or disable various groups of front panel operations
For more information, see the Embedded Web Server's online help.
If you forget the administrator password, you can delete the current password from the front panel: select the Connectivity menu icon , then Advanced > Embedded Web Server > Reset EWS access control.
Access to the Networking page is protected by a different password (the administrator's password). To reset the administrator's password, you need to reset the whole input/output configuration. Using the front panel, select the Connectivity menu icon , then select your connection method (e.g. Gigabit Ethernet), then Restore factory settings.
This will reset the whole input/output configuration, the printer will reset to the DHCP configuration method and its IP address could change.
Country: Flag Bulgaria
