HP s1931a Monitor - Product Specifications
The HP s1931a is a 47 cm (18.5 inch) wide-screen monitor with liquid crystal display (LCD).
Figure : Photo of the HP s1931a LCD wide-screen monitor
WS098AA
Features
The HP s1931a LCD wide-screen monitor has the following features:
  • 1366 x 768 factory-set resolution
  • Supports DVI-D and VGA video input connectors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
47 cm (18.5 inch) diagonal and viewable image
Panel active area (width x height): 40.89 cm x 22.98 cm (16.1 inches x 9.05 inches)
Display type
Liquid crystal display (LCD)
Input terminal
1 DVI-D connector
1 VGA connector
Integrated speakers
1.5 watts per channel
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1366 x 768 @ 60Hz (same as max and native)
Contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 15,000:1 (typical)
Dynamic Contrast Ratios up to 15,000:1 during video playback only, depending on series of frames or time duration.
Response time
5 ms (typical)
Pixel pitch
0.3 mm (horizontal and veritcal)
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected through the HDMI or DVI connector. A monitor without HDCP support, or connected through analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. HDCP prevents transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption:33 Watts max power consumption (26 Watts typical power consumption) , <1 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 10% RH through 85%, 38.7 degrees C max wet-bulb RH (non-condensing)
Dimensions
H x W x D (unpacked):
34.49 x 44.80 x 18 cm (13.58 x 17.64 x 7.09 inches)
Unpacked: 3.6 Kg (7.94 lbs)
Country: Flag Bulgaria
