Replacing the Printhead for HP Photosmart e-All-in-One Printers (B010a and B010b)
This document is for the HP Photosmart e-All-in-One Printers (B010a and B010b).
A printhead assembly is formed by cartridges fitted into printheads. A new printhead assembly might need to be installed when the existing printhead assembly is damaged or is incompatible with the printer. Replacement printhead assemblies are only available from HP Support or authorized service providers.
Order the Printhead Assembly
These steps apply to all countries/regions except the United States.
If HP replaces your printhead assembly under warranty, you receive a new printhead assembly, cleaning materials, and a full set of new ink cartridges with the replacement printhead.
If your printhead assembly is no longer under warranty, you can purchase a new one online.
  1. Go to the HP How to Buy website, and then click your country-language.
  2. A Buy HP page displays. Look for the HP Parts store on this page. The location of the HP Parts store varies depending on your region. Click HP Parts store.
  3. Under Find your part(s), type CN643A in the Search by part number text box. Follow the on-screen instructions to order the printhead assembly.
Replace the printhead assembly
Follow these steps to replace the printhead assembly.
Wait until a new printhead assembly is available before removing the cartridges. Do not leave the cartridges outside of the printer for longer than 30 minutes. Leaving the printhead and cartridges outside the printer for long periods can damage the printer and the supplies.
Step one: Remove the old cartridges
  1. Press the Power button to turn on the printer, if it is not already turned on.
  2. Open the cartridge door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before you continue.
    Figure : Open the cartridge door
    Image: Open the cartridge door
  3. Press the tab on the front of the old cartridge to release it, and then remove the cartridge from the slot.
    Figure : Remove the cartridge from the slot
    Image: Remove the old cartridge from the slot
  4. Repeat the previous step for each cartridge.
Step two: Remove the old printhead
The printer shown in the following videos might look different than your printer, but the steps still apply.
  1. Lift the latch handle on the carriage until it stops.
    Figure : Lift the latch handle
    Image: Lift the latch handle
  2. Lift the printhead to remove it from the carriage.
    Figure : Remove the printhead
    Image: Remove the printhead
Step three: Clean the electrical contacts inside the printer
For successful printhead assembly replacement, it is important to make sure the electrical contacts inside the printer are as clean as possible. The replacement printhead assembly comes with pre-moistened wipes.
Figure : Pre-moistened wipes
Image: Pre-moistened wipes
Use these wipes to clean the electrical contacts inside the printer. As the wipes become dirty, discard them and use new ones.
Wiping the electrical contacts up and down or from side to side might damage the printer. Wipe from the top of the electrical contact to the bottom of the electrical contact, in one direction only.
Figure : Clean the contacts
Image: Clean the contacts
Step four: Install the new printhead
  1. Remove the new printhead from its package.
    Figure : Remove the new printhead
    Image: Remove the new printhead
    Do not touch the copper-colored electrical contacts. Do not scratch the electrical contacts on the printer or any other surface.
    Figure : Do not touch the electrical contacts
    Image: Do not touch the electrical contacts
  2. Hold the printhead upright with the colored shape icons on the top.
  3. Lower the printhead into the carriage.
    Make sure that the colored shapes on the sides of the printhead line up with the colored shapes on the carriage.
    Figure : Install the new printhead
    Image: Install the new printhead
  4. Carefully lower the latch handle.
    Figure : Lower the latch handle
    Image: Lower the latch handle
Step five: Load plain paper
  1. Lower the tray.
  2. Pull out the tray extender and raise the paper catch.
      Figure : Paper extender and paper catch
      Illustration of tray extender and paper catch
    1. Tray extender
    2. Paper catch
  3. Slide the paper width guide to its outermost position.
    Figure : Slide the paper width guide outward
    Illustration of sliding the paper width guide outward
  4. Load letter or A4, unused, plain, white paper into the tray with the short edge forward and print side down.
    Figure : Insert the paper into the tray
    Illustration of inserting paper into the tray
  5. Slide the paper width guide inward so it rests against the stack of paper.
    Figure : Slide the paper width guide inward
    Illustration of pushing the paper width guide against the stack of paper
Step six: Install the new cartridges
Use the following steps to install new cartridges.
Do not reuse the old cartridges. They might damage the new printhead.
  1. Press the Power button to turn on the printer, if it is not already turned on. Wait until the printer is idle and silent before continuing.
    The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
  3. On the new cartridge, pull the orange pull-tab straight back to remove the plastic wrap.
    Figure : Remove the plastic wrap
    Image: Unwrap the new cartridge
  4. Twist the orange cap counter clockwise to snap it off.
    Figure : Remove the orange cap
    Image: Twist the orange cap to remove it
  5. With the cartridge contacts facing the printhead, slide the cartridge into the empty slot. Press down on the cartridge until it clicks firmly into place.
    Figure : Install the cartridge
    Image: Install the new cartridge
  6. Repeat these steps to install the other cartridges.
  7. Close the cartridge door. The carriage moves back to the side of the printer.
    Figure : Close the cartridge door
    Image: Close the cartridge door
Step seven: Align the printer
If the printer alignment does not start automatically, use the following steps to align the printer.
  1. Load letter or A4, unused, plain, white paper into the input tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start, click All Programs, click HP, and then click HP Solution Center.
    • Windows Vista and Windows 7: Click the Windows icon (), click All Programs, click HP, and then click HP Solution Center.
    HP Solution Center opens in a new window.
  3. Click Settings ().
  4. Under Print Settings, click Printer Toolbox. The printer Toolbox opens in a new window.
  5. Click the Device Services tab.
  6. Click Align the Printer, and then click OK. The printer prints an alignment page.
    Figure : Alignment page
    Image: printer alignment page
  7. Load the page print-side down on the right front corner of the glass, and then press OK to scan the page and complete the alignment process.
    Important: An alignment page continues to print every time you turn on the printer until you scan the alignment page. Scan the alignment page to complete the alignment process.
Step eight: Return failed parts to HP
If the new printhead assembly came with a post-paid mailing label and instructions to return the failed parts to HP, please do so. HP would like to analyze the parts in order to improve our printers in the future.
If the new printhead assembly did not arrive with a post-paid return mailing label, you are done, and there is no need to continue troubleshooting.
The printhead and cartridges depicted might differ slightly from yours, but the steps are the same.
  1. Place the old printhead into the plastic package that the new printhead arrived in.
    Figure : Put the old printhead into the package
    Image: Put the old printhead into the package
  2. Peel off the lid sticker labeled B, and then seal the printhead package with it.
    Figure : Peel off the lid sticker
    Image: Peel off the lid sticker
    Figure : Seal the package with the lid sticker
    Image: Seal the package with the lid sticker
  3. Cap the old cartridges with the orange caps that came on the new cartridges.
    Figure : Cap the old cartridges
    Image: Cap the old cartridges with the orange caps that came on the new cartridges.
  4. Put the old parts and the form that came with the new parts into the box that the new parts came in. If possible, also include a printout that shows the issue with the old printhead.
    Figure : Put the old parts, form, and sample printout into the box
    Image: Put the old parts, the form, and printout into the box
  5. Close the box, apply the post-paid mailing label, and then mail the box.
    Figure : Send the box back to HP
    Image: Send the box back to HP
