HP Z200 Workstation - 6 Beeps at Power On, No Boot
Issue
Six beeps at the Power On Self Test indicate a video issue. Either the graphics device is not present or it is malfunctioning.
There are specific considerations for the z200 Workstation series. Depending on the installed CPU type some systems have integrated video, some do not have integrated video and thus need a add-in PCI-E graphics card to work.
Solution
  1. Make sure that the system contains a PCI-E video card or a CPU type that features video: Integrated Graphics is embedded on Intel dual-core Processors i5/i3/Pentium/Celeron Series, not on Intel quad-core Xeon Processor 3400 Series.
  2. If it does not work, reseat the PCI-E graphics card.
  3. If reseating the PCI-E graphics card did not resolve the issue, then replace the PCI-E graphics card.
