Press the Setup Tab, Options, Scanning to reach the Scan Options dialog.
Figure : Scan Options dialog screen
Preview dpi
Setup Tab, Options, Scanning, Preview dpi
Determine the image resolution (between 50 and 300 dpi) for on screen previewing. Lower resolutions give faster previewing.
Eject paper
Setup Tab, Options, Scanning, Eject paper
Use this option to make the scanner eject the paper automatically after each scan.
Auto preview
Setup Tab, Options, Scanning, Auto preview
Use this option to automatically run a preview of the output as soon as an original is loaded in the scanner.
Scan speed - fixing backups
Setup Tab, Options, Scanning, Scan speed
Sometimes, the performance of your workstation will cause the scanner to make repeated "back-ups" during scanning in order to ensure correct and continuous processing of scanned data. Back-ups can be avoided by reducing the maximum scanning speed thus refitting the scanner's performance to that of your workstation. The Default button can be used to restore the default scan speed value.
Rewind paper
Setup Tab, Options, Scanning, Rewind paper
After scanning, your original will normally be found hanging at the back of the scanner. If the scanner is placed close to a wall, it may be difficult to access the original in order to remove it from the scanner. However, if the Rewind Paper option is selected, the original will be rewound back to its starting position after scanning. In this case, it can be ejected and removed from the front of the scanner.
Height auto-size method
Setup Tab, Options, Scanning, Height auto-size method
There are two methods the scanner software can use to detect the height (length) of the image: Paper detects the end of the paper by mechanical means, while Image performs a prescan of the image and uses software to work out the length of the prescanned image. The Paper method is quicker because it doesn't require a prescan; but the Image method may be more accurate (if the paper is longer than the image).
Limit auto-detect scan length
Setup Tab, Options, Scanning, Limit auto-detect scan length
This option is provided so that you can set a maximum to the auto-detected length of an image.
