HP Compaq nc4010 Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the keyboard for the HP Compaq nc4010 Notebook PC.
Minimum skill level
Tools required
  • Torx #8 (T8) screwdriver
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboard
325530-xx1 (Original)
No
The part number may vary based on the country. Click here for a list of country specific spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Remove the T8-8 mm screw near the center of the base enclosure.
  3. Turn the notebook right side up and open the display panel fully.
  4. Use a plastic flat-bladed tool or your finger to lift the top edge of the keyboard and slide the bottom edge toward the display.
  5. Lift the bottom edge and pull it back until the keyboard is resting on the top cover.
  6. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  7. Remove the keyboard ribbon cable from the ZIF connector.
  8. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board.
  9. Remove the pointing stick ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover.
  2. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board.
    Use care to prevent damaging the pointing stick ribbon cable.
  3. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  4. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  5. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  6. Lift the keyboard and move it toward the rear of the notebook.
  7. Toe the tabs on the bottom edge of the keyboard into the top cover and press the keyboard flat.
  8. Close the display panel and turn the notebook upside down.
  9. Replace the T8-8 mm screw.
Country: Flag Bulgaria
