HP Compaq nc4010 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP Compaq nc4010 Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head (P0 and P1) screwdriver
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
30GB SMART Ultra ATA-100 hard drive - 4,200 RPM, 9.5 mm form factor
325522-001 (Original)
Yes
40GB SMART Ultra ATA-100 hard drive - 5,400 RPM, 9.5 mm form factor
325523-001 (Original)
Yes
60GB SMART Ultra ATA-100 hard drive - 5,400 RPM, 9.5 mm form factor
325524-001 (Original)
Yes
80GB ATA-5 IDE hard disk drive - 5,400 RPM, 2.75-inch form factor (9.5 mm height) - Includes hard drive bezel and frame
345632-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard Disk Drive (HDD) from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the 3 mm P1 Phillips-head screw that secures the hard disk drive.
  3. Lift the plastic locking mechanism above the base enclosure.
  4. Pull the hard disk drive out of the bay by the locking mechanism and remove.
  5. If present, remove the hard disk drive PIN extender. Click here for instructions on removing the hard disk drive PIN extender.
    This procedure not shown in video.
  6. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. If required, replace the hard disk drive PIN extender. Click here for instructions on replacing the hard disk drive PIN extender.
  3. Lift the plastic locking mechanism on the hard disk drive.
  4. Slide the hard disk drive into the bay and push it in until the connector is seated.
  5. Press down on the locking mechanism until it is flush with the base enclosure.
  6. Replace the 3 mm P1 Phillips-head screw.
