HP EliteBook 2740p Tablet PC Specifications
Product image
Product features
Feature
Mobile Intel QM57 Express Chipset
Processor1
Intel Standard Voltage Processor, soldered:
  • Intel Core i7-620M Processor (2.66-GHz, 4MB L3 cache)2 Up to 3.33 GHz with Intel Turbo Boost Technology
  • Intel Core i5-540M Processor (2.53-GHz, 3MB L3 cache)2 Up to 3.06 GHz with Intel Turbo Boost Technology
  • Intel Core i5-520M Processor (2.4-GHz, 3MB L3 cache)2 Up to 2.93 GHz with Intel Turbo Boost Technology
Memory
Standard: DDR3 PC3-10600 SDRAM (1333 MHz)3 Two SODIMM slots supporting dual-channel memory 1024MB, 2048MB and 4096MB SODIMMs.
Maximum Upgradeable to 8192MB with 4096MB SODIMMs in slots 1 and 2.
Dual-channel Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels.
Graphics
Intel HD Graphics
Microsoft DirectX 10 (Shader 4.0) and OpenGL 2.1 capable
Internal:
  • 12.1-inch diagonal LED-backlit WXGA ultra wide viewing angle anti-glare (1280 x 800)
  • Digitizer only or Digitizer and Multi-touch
  • Optional Outdoor View4
  • Ambient light sensor
External: Up to 32-bit per pixel color depth
  • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. U.S. and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 mm x 19 mm key pitch (center-to-center spacing), 2.0 mm stroke, and comfort-dished keycaps.
HP DuraKeys is a clear coating applied over the notebook keyboard that helps protect the finish and the printed characters on the keys. HP DuraFinish helps protect the finish on the keyboard deck, graphics, and icons from normal wear and tear.
HP Night Light shines directly on keyboard for low-light conditions.
Touch-sensitive controls
Touch-sensitive controls provide easy access to the following features: HP QuickLook 3, HP QuickWeb, wireless on/off, touchpad on/off, volume mute, volume down, volume up.
Pointing device
  • Dual pointing (Touchpad with scroll zone and Pointstick, each with two pick buttons)
  • Digital Eraser Pen with tether and clip
  • Multi-touch screen gestures
Expansion card slots
ExpressCard/34 slot Supports: ExpressCard/34
Integrated Smart Card Reader: Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
Secure Digital slot: Supports SD (Secure Digital), MMC (MultiMedia Card)
External Optical Drive
Via optional HP 2740 Ultra-Slim Expansion Base: 9.5 mm DVD+/-RW SuperMulti Drive
Via optional HP External USB CD/DVD R/RW Drive
Power Supply
65 W Smart AC adapter, 1.8-meter (6-foot) power cord included
Battery
Primary Battery:
  • HP 6-cell 44 WHr Li-Ion Primary Battery with fuel gauge LEDs
  • HP Long Life 6-cell 39 WHr Li-Ion Primary Battery
1: Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
2: Intel's numbering is not a measurement of higher performance.
3: Memory bus runs at a maximum of 1066 MHz.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
4: Outdoor View is an option available only with both Digitizer and Multi-touch that provides enhanced viewing:
  • 12% increase in front of screen display brightness with no loss of battery life
  • Up to 235% increase in contrast, resulting in better viewability, at wide viewing angles
  • 25% less specular reflections in bright light
  • 91% less diffuse reflections in bright light
  • 67% more contrast in bright sunlight
This data is based on typical measurements by the display manufacturer. Actual measurements may vary from panel to panel.
Communications
Features
HP un2420 EV-DO/HSPA Mobile Broadband Module
Technology/Operating Bands: GSM/GPRS/EDGE: 850 MHz(Cell), 900 MHz(EGSM), 1800 MHz(DCS), 1900 MHz (PCS)
Wireless Protocol Standards:
GSM/GPRS/EDGE: Class B, Multi-slot operation, coding schemes CS1 – CS4 and MSC1 – MSC9
UMTS/WCDMA: Release 99 and Release 6
CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-2000
Atheros 9285G 802.11b/g/n 1x1 WiFi Adapter
  • Wi-Fi certified
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel Centrino Advanced-N 6200
Integrated support for 802.11a, b, g, and n2 Up to 300 mb/s data rate
Broadcom 4322AGN 802.11a/b/g/n WiFi Adapter
Broadcom 4312G 802.11b/g WiFi Adapter
Integrated support for 802.11 b and g Up to 54 mb/s data rate
HP Integrated Module with Bluetooth Wireless Technology
1: Height varies depending upon where on the tablet the measurement is made. Starting weight includes 6-cell battery, hard drive, 2GB memory, 802.11 wireless communications module. Weight varies by configuration and components.
2: In countries where 802.11n is not allowed, this capability is not enabled.
Audio/Visual
Features
Audio/Visual
  • High Definition Audio support
  • Integrated stereo speakers
  • Integrated dual-microphone array
  • Touch-sensitive controls for volume up, volume down, and mute Combo headphone/microphone jack
  • Optional 2 MP webcam with Business Card Reader software
    • Supports videoconferencing and still image capture
    • Large image sensor for excellent color matching and good low light sensitivity
    • Up to 30 frames/sec
    • Video capture at VGA, 1.3 Mpixel, and 2 Mpixel resolutions
    • AutoMacro focus lens
    • 16-bit true color (camera sensors output YCrCb format among others)
Physical specifications
Features
Chassis Dimensions (H x W x D)
31.7 (at front) x 290 x 212 mm x 1.25 (at front) x 11.42 x 8.35 in
System Weight1
1.72 kg (3.30 lb)
Temperature
Operating:
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating: –4° to 140°C (–20° to 60°F)
Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Altitude
Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Power
External 65 W Smart AC adapter, 1.8 meter (6-foot) power cord included
Software/OS
Feature
Operating System
  • Genuine Windows Vista Business
  • Genuine Windows 7 Professional Edition
  • Windows XP Professional
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
