HP Laserjet P1505 and P1505n Printers - 'Out of Paper' Error Message Displays and the Printer Does Not Pick Up or Feed Paper
Issue
The 'Out of Paper' error message displays on the computer, and the product does not pick up or feed the paper from the tray. The product might make noises as though it is printing, but no paper moves through it.
How to use the solutions in this document
To resolve the issue, try each step in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly.
How to print a self-test report
  1. Press the Power button () to turn on the product.
  2. Press and release the Go button (). The self-test report prints.
Solution one: Perform a power reset
Sometimes, restarting the product can clear a paper feed issue. Follow these steps to perform a reset.
Step one: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet.
  3. Wait at least 15 seconds.
  4. Plug the power cord back into the wall outlet.
  5. Reconnect the power cord to the printer.
  6. Turn the printer on.
Step two: Print a self-test report
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints, try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the issue persists, continue with the next solution.
  • If the self-test report does not print, continue with the next solution.
Solution two: Check the condition of the paper, and then reload it
Paper feed issues might result from dusty, torn, wrinkled, wet, or folded paper in the tray. The quality of the paper can also make a difference. Use only good quality paper that meets product specifications. Follow these steps to check the condition of the paper.
For the purposes of these troubleshooting steps, use only 10 to 25 sheets of plain white, unused paper.
Step one: Check the condition of the paper
  1. Remove the stack of paper from the tray.
  2. Check for obstructions inside the tray. Use a flashlight to view the mechanism inside the tray to make sure that nothing blocks the paper from engaging with the rollers. Even small pieces of paper can cause paper feed issues.
    If you find obstructions in the paper path, skip to the section on cleaning the rollers.
  3. Examine the condition of the paper, and then replace any ripped, dusty, curled, wrinkled, or bent paper.
  4. Make sure that all the paper in the stack is the same size and type. Never load mixed types of paper in the tray. The product can only process one type of paper at a time.
  5. Tap the stack of paper on a flat surface to align the edges.
  6. Make sure that the stack of paper contains no fewer than 10 sheets and no more than 25 sheets of paper.
    You need to use 10 to 25 sheets of paper only for purposes of these troubleshooting steps. When the issue is resolved, you can resume loading paper according to the paper tray capacity specifications for your product.
Step two: Reload the paper
Be aware of the paper capacities before loading paper.
The main tray holds up to 250 pages of 75 g/m2 paper, or fewer pages of heavier paper. The height of the paper stack should not exceed 25 mm (.98 in.).
Load paper with the top forward and the side to be printed on facing up. To prevent jams and skewing, always adjust the side and front paper guides.
Figure : Load paper in the input tray
Illustration: Loading paper in the input tray
When you add new paper, make sure that you remove all the paper from the tray and straighten the entire stack. This helps prevent multiple sheets of paper from feeding through the product at one time, reducing paper jams.
Step three: Print a self-test report
Solution three: Adjust the settings in the print driver
The product might not pick up paper if the paper size and type in the paper tray do not match the size and type settings in the print driver. This feature of the product helps to avoid wasting ink and paper if the paper is not what you expected.
  1. Return to the document you were trying to print when the issue occurred.
  2. Click File, and then click Print. The Print window opens.
    Figure : Click File, and then click Print
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties, Options, Printer Setup, Printer, or Preferences.
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality.
  5. From the Type is drop-down list, select the paper type that matches the paper in the product.
  6. From the Size is drop-down list, select the paper size that matches the paper in the product.
    For example, if you have 101.6 x 152.4 mm (4 x 6 inch) photo paper loaded in the paper tray, select 4x6in. or 4x6in. (tab).
    If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
    1. Select Custom from the Size is drop-down list, or the Custom tab.
    2. In the Custom Paper Size dialog box, type a name for the new custom size.
    3. In the Width and Height boxes, or the Width and Length boxes, type the dimensions.
    4. Select the unit of measurement, and then click Save.
    5. Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
      You must exit the Properties dialog box to apply your changes.
    6. Open the Properties dialog box again, and then select the new custom size from the Size is drop-down list.
  7. Click OK, and then click OK again to print the document.
  • If the document prints, the issue is resolved, and there is no need to continue troubleshooting.
  • If the document prints on plain white paper, but not a special paper type, there is no need to continue troubleshooting. The problem is probably related to the paper that you were trying to print on, or possibly a connectivity problem. Review the Cause and Prevention sections at the end of this document to check other possibilities.
  • If the document does not print, continue with the next solution.
Solution four: Clean the pickup roller
Follow these steps to clean the pickup roller.
Step one: Clean the pickup roller
  1. Press the Power switch to turn off the product, and then disconnect the power cord from the back of the product. Wait for the product to cool.
    Figure : Disconnect the power cord
    Illustration: Disconnecting the power cord from the back of the product
  2. Open the print cartridge door, and then remove the print cartridge.
    To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.
    Figure : Remove the print cartridge
    Illustration: Removing the print cartridge
  3. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity.
    Figure : Clean the print cartridge cavity
    Illustration: Cleaning the print cartridge cavity
  4. Find the pickup roller inside the product.
    Figure : Pickup roller
    Illustration: Location of the pickup roller
  5. Release the small, white tabs on either side of the pickup roller, and then rotate the pickup roller toward the front.
    Figure : Release the tabs
    Illustration: Releasing the tabs on either side of the pickup roller
  6. Gently pull the pickup roller up and out.
    Figure : Remove the pickup roller
    Illustration: Removing the pickup roller
  7. Dab a clean, lint-free cloth in rubbing alcohol (isopropyl alcohol) or clean water, and then scrub the pickup roller.
    Use only distilled, filtered, or bottled water to clean the pickup roller. Tap water might contain contaminants that can damage the pickup roller.
      warning:
    Rubbing alcohol is flammable. Keep the rubbing alcohol and cloth away from any open flame or heat source. Before you close the product, allow the rubbing alcohol to dry completely.
  8. Using a clean, dry, lint-free cloth, wipe the pickup roller to remove loosened dirt.
  9. Allow the pickup roller to dry completely before you reinstall it in the product
  10. Position the pickup roller in the slot. The circular and rectangular slots on each side will prevent you from installing the roller incorrectly.
    Figure : Position the pickup roller in the slot
    Illustration: Positioning the pickup roller in the slot correctly
  11. Rotate the top of the pickup roller away from you until both sides snap into place.
    Figure : Rotate the pickup roller into place
    Illustration: Rotating the pickup roller into place
  12. Reinstall the print cartridge, and then close the print cartridge door.
    Figure : Reinstall the print cartridge
    Illustration: Reinstalling the print cartridge
  13. Reconnect the power cord to the back of the product, and then press the Power switch to turn on the product.
    Figure : Reconnect the power cord
    Illustration: Reconnecting the power cord to the back of the product
Solution five: Replace the pickup roller
Follow these steps to replace the pickup roller with a new one.
Step one: Replace the pickup roller
  3. Find the pickup roller inside the product.
  4. Release the small, white tabs on either side of the pickup roller, and then rotate the pickup roller toward the front.
  5. Gently pull the pickup roller up and out.
  6. Position the new pickup roller in the slot. The circular and rectangular slots on each side will prevent you from installing the roller incorrectly.
  7. Rotate the top of the pickup roller away from you until both sides snap into place.
  8. Reinstall the print cartridge, and then close the print cartridge door.
  9. Reconnect the power cord to the back of the product, and then press the Power switch to turn on the product.
Solution six: Service the product
If the product printed a self-test report with plain white paper, the printer is functional and does not need service. Other issues, such as connectivity, print driver settings, special paper, photo paper facing shiny side up, or slick or damaged paper might cause the problem. Review the following sections to learn about the common causes and how to prevent the issue.
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
