    Fix HP Printer issue on macOS
Replacing the Printhead for HP Officejet Pro 8500A e-All-in-One Printer Series
This document contains steps for removing the printheads from the product, and then installing replacement printheads.
Replacing the printheads
Follow these steps to remove the old printheads, and then install the replacement printheads.
Step one: Load the paper tray
Follow these steps to load paper into the main tray (paper tray 1).
  1. Lift the output tray until it locks in an open position.
  2. Pull the bottom of the tray toward you until it stops.
  3. Slide the paper width guides to their outermost positions.
  4. Insert up to 250 sheets of plain white paper in the center of the tray, with the print side down and short edge forward. Make sure that the stack of paper aligns with the engraved lines in the tray.
    Figure : Load plain white paper
    Illustration of loading plain white paper
  5. Slide the paper width guides inward so they rest on the edges of the paper.
    Figure : Adjust paper width guides
    Illustration of adjusting the paper width guides
  6. Push the bottom of the tray toward the product until it locks into place.
  7. Lower the output tray.
Step two: Remove the old printhead
  1. Open the carriage access lid.
  2. Touch Change Printheads on the product control panel. The carriage moves to the access area on the left side of the product. Wait for the carriage to stop moving.
    Do not proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and on, and then touch Change Printheads on the product control panel again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  3. Lift the printhead latch.
    Figure : Lift the printhead latch
    Illustration of lifting the printhead latch.
  4. Lift the handle of the old printhead, and then use it to pull the printhead out of its slot.
    Figure : Remove the printhead
    Illustration of removing the printhead
Step three: Install the new printhead
  1. Shake the printhead up and down at least six times while the printhead is still in its packaging.
    Figure : Shake the printhead six times
    Illustration of shaking the printhead six times
  2. Remove the printhead from its packaging, and then remove the orange protective caps from the nozzles.
    Figure : Remove the protective caps
    Illustration of the removing the printhead from the packaging and the protective caps from the printheadDo not touch the nozzles on the printhead. Touching the nozzles can permanently damage the printhead.Do not touch the printhead nozzlesIllustration of cautioning against touching the printhead nozzles
  3. Hold the printhead by its sides with the nozzles toward the product, and then insert the printhead into its color-coded slot.
    • Insert the black/yellow printhead into the slot on the left.
    • Insert the magenta/cyan printhead into the slot on the right.
    Figure : Insert the printhead into its slot
    Illustration of inserting the printhead into its slot
  4. If needed, repeat these steps to install the other printhead. Make sure that you shake the other printhead back and forth six times before installing it.
  5. Lower the printhead latch, and then press down until the latch snaps into place.
    Figure : Lower the printhead latch
    Illustration of lowering the printhead latch
  6. On the control panel display, touch Done.
  7. Close the product lid. The product initializes the printheads, and then prints the alignment pages. This could take several minutes.
