A 'Paper jam or misfeed' Message Displays for HP Photosmart Premium Fax All-in-One Printers (C410a, C410b, C410c, C410d, and C410e)
Issue
During printing, the paper becomes stuck in the product and the error message 'Paper jam or misfeed' displays on the control panel.
Experiencing frequent or recurring paper jams?
If you are looking for information on preventing a paper jam from recurring, you can skip to the prevention and cause sections in this document.
To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting.
Print a self-test report
Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. On the product control panel, press Setup ().
  3. Press OK to select Print Report.
  4. Press OK to select Printer Status Report.
    The product prints the printer status report.
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue.
Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. The following solutions apply to both real and false paper jams.
Solution one: Clear the jam from the product
Follow these steps to check for and clear a paper jam from the product.
Remove any loose sheets of paper from the input tray and the output tray.
Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism.
Remove any loose paper
Do not pull jammed paper
Illustration of loose paper in input tray
Illustration cautioning against pulling jammed paper
Step two: Clear the jam from the rear of the product
Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Disconnect the USB cable from the rear of the product.
  2. Press the Power button () to turn off the product.
  3. Turn the product so that you can access the rear side.
  4. Push the right side of the duplexer to the left, and then pull out the duplexer. Set the duplexer aside.
  5. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    Figure : Remove the jammed paper
    Illustration of removing jammed paper from rear of product
    Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
    Figure : Remove scraps of paper
    Photograph of removing scraps of paper
  6. Remove any paper from the top zone of the paper path.
    Figure : Paper path top zone
    Photograph of the top zone of the paper path.
  7. Hold the duplexer in front of you, and then press the tabs on both sides of the duplexer to open it.
    Figure : Location of the tabs on the duplexer
    Illustration: Location of the tabs on the duplexer
  8. Gently pull any jammed paper out of the duplexer.
  9. Close the door of the duplexer.
  10. Insert the two pegs on the left side of the duplexer into the left side of the product, and then gently push the duplexer in. Make sure that the duplexer is firmly in place.
Step three: Clear the jam from the front of the product
  1. Without opening the cartridge access door, check the output tray for jammed paper.
  2. If you see jammed paper, gently pull it out.
    Carefully remove paper from the front of the product. Pulling too hard on jammed paper can damage the print mechanism.
  3. Open the cartridge access door.
    Illustration of opening the cartridge access door
    The carriage might try to move into the access area. If it does, allow it to move to that position.
  4. Check for any jammed paper inside the product.
    Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper.
  5. Close the cartridge access door.
    Figure : Close the cartridge access door
    Illustration of closing the cartridge access door.
  6. Reconnect the power cord to the rear of the product.
  7. Press the Power button () to turn on the product.
Step four: Print a self-test report
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If these steps resolved the issue, and the test page prints, there is no need to continue troubleshooting.
  • If the issue persists, continue with the next solution.
  • If the test page does not print, continue with the next solution.
Solution two: Make sure that the carriage moves freely
Use the following steps to make sure that the carriage moves freely.
Step one: Check the paper path
  1. If the product is not turned on, press the Power button () to turn it on.
  2. Open the cartridge access door.
  3. With the product turned on, disconnect the power cord from the rear of the product.
  4. Unplug the power cord from the power source or electrical outlet.
      warning:
    You must unplug the power cord to move the carriage by hand and reset the paper feed mechanism without the risk of electrical shock.
  5. Check for any paper or objects that might be restricting the carriage.
    Figure : Example of paper that might restrict the carriage
    Illustration of paper in carriage path that might restrict the carriage
  6. Remove any paper or objects you find.
    If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  7. Reach inside the product through the cartridge access door, and then manually move the carriage.
    • If the carriage is stuck on the right side, move the carriage to the left side of the product.
    • If the carriage is stuck on the left side, move the carriage to the right side of the product.
    • If the carriage is stuck in the middle, move the carriage to the right.
  8. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the right.
  9. Close the cartridge access door.
  10. Reconnect the power cord to the rear of the product.
  11. Plug the power cord back into the power source or electrical outlet.
  12. Press the Power button () to turn on the product.
Step two: Print a self-test report
Solution three: Clean the rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers.
Step one: Clean the rollers in the rear access area
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
    • A clean, lint-free cotton swab
  4. Disconnect the power cord from the rear of the product.
  5. Push the right side of the duplexer to the left, and then pull out the duplexer. Set the duplexer aside.
  6. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  7. Press the cloth against the rollers in the product, and then rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Figure : Clean the rollers in the product
    Photograph: Clean the rollers in the product
  8. Look inside the rear access area of the product to find the pick rollers. They are near the center of the product behind the paper feed rollers.
    Figure : Location of the pick rollers
    Photograph of the location of the pick rollers
    You might need to use a flashlight to illuminate the pick rollers.
  9. Lightly dampen a clean, lint-free cotton swab, and then use it to clean the pick rollers.
      Figure : The pick rollers
      Photograph of the pick rollers inside the product
    1. Pick roller
    2. Small pick roller
  10. Allow the rollers to dry for 10 or 15 minutes.
Step two: Clean the rollers in the duplexer
  1. Hold the duplexer in front of you, and then press the tabs on both sides of the duplexer to open it.
  2. Check the paper feed rollers in the duplexer to make sure that they are clean, free of paper bits, and rotate freely.
    Figure : Check the rollers in the duplexer
    Photograph: Check the rollers in the duplexer
  3. Clean the rollers of the duplexer the same way you cleaned the rollers inside the product.
  4. Allow the rollers of the duplexer to dry for 10 or 15 minutes.
  5. Insert the two pegs on the left side of the duplexer into the left side of the product, and then gently push the duplexer in. Make sure that the duplexer is firmly in place
Step three: Print a self-test report
Solution four: Reset the product
Follow these steps to reset the product.
Step one: Perform a power reset
  1. Press the Power button () to turn on the product.
  2. With the product turned on, disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  7. If the product does not turn on by itself, press the Power button () to turn it on.
  • If these steps resolved the issue, and the self-test report prints, there is no need to continue troubleshooting. Connect the USB cable to continue the print job.
  • If the issue persists, continue to the next step.
  • If the self-test report does not print, skip to the next solution.
Step three: Search for more information
If you are still experiencing issues, see the HP Product Support Home Page, and then search for another document that relates to the symptoms you are experiencing.
Right-click this link, Product Support Home Page, and then click Open in New Window.
If the page displays in the wrong country/region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct country/region and language.
Preventing paper jams
Use the following suggestions to prevent paper jams.
The following recommendations can help prevent recurring paper jams in your HP product.
  • Before loading paper in the tray, hold the stack of paper, and then tap the bottom edge on a flat surface so that the stack is even on all sides.
  • Make sure that the length and width adjusters on the tray are correctly positioned, and then push the stack of paper forward until it stops in the tray.
    Do not force the paper to move too far forward in the tray.
  • Do not overload the tray with paper.
  • Only add paper to the tray when the product is not printing.
  • Make sure the HP product supports the paper type. See the documentation that came with the HP product for more information.
  • Do not print on paper with paper clips or staples attached.
  • Do not use paper that is bent, torn, dusty, damp, wrinkled, curled, or paper that does not lie flat.
  • Use only one type of paper at a time. Do not mix different types, weights, or sizes of paper.
  • Do not use paper that is too thin, too thick, or too glossy for the product.
The following factors can cause paper jams:
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
