Compaq Evo n610c Notebook PC - Removing and Replacing the Memory Expansion Board
This document is provided to assist in removing and replacing the memory expansion board for the Compaq Evo n610c Notebook PC.
Minimum skill level
Tools required
Small flat-bladed alignment tool (non-metallic).
Parts required
The replacement part number will vary depending on the memory expansion board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
512MB, 133 MHz, PC133, SDRAM (S.O.DIMM) memory module
238879-001 (Original)
Yes
256MB, 133 MHz, PC133, SDRAM (S.O.DIMM) memory module
212683-001 (Original)
Yes
128MB, 133 MHz, PC133, SDRAM (S.O.DIMM) memory module
212682-001 (Original)
Yes
64MB, 133 MHz, PC133, SDRAM (S.O.DIMM) memory module
212681-001 (Original)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the memory expansion board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory expansion board from the menu on the upper left hand side of the screen.
Click here to view the memory expansion board removal video (right-click on the link to open in a new window/tab).
Memory expansion board removal
  2. Locate the notch in the memory expansion cover.
  3. Insert a non-metallic, flat-bladed tool into the notch and lift the memory expansion cover.
  4. Slide a non-metallic tool along the edge of the memory expansion cover to free it from the top cover.
  5. Push both arms outward simultaneously to release the memory expansion board to the spring tension position.
  6. Grasp the memory expansion board by the edges and pull gently to remove it.
  7. Place the memory expansion board in a static dissipative bag.
Memory expansion board replacement
  1. Remove the memory expansion board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the memory expansion board by the edges and push gently to replace it.
  4. Press the memory expansion board down to latch the arms.
  5. Toe the memory expansion cover into the outside edge of the enclosure.
  6. Press down on the inside edge of the memory expansion cover until it snaps into place.
Memory expansion board installation
  1. Locate the notch in the memory expansion cover.
  2. Insert a non-metallic, flat-bladed tool into the notch and lift the memory expansion cover.
  3. Slide a non-metallic tool along the edge of the memory expansion cover to free it from the top cover.
  4. Remove the memory expansion board from the static dissipative bag.
  5. Locate the alignment slot and align it to the empty board receptacle.
  6. Grasp the memory expansion board by the edges and push gently to replace it.
  7. Press the memory expansion board down to latch the arms.
  8. Toe the memory expansion cover into the outside edge of the enclosure.
  9. Press down on the inside edge of the memory expansion cover until it snaps into place.
Verifying successful repair
Power on the notebook PC and verify whether the BIOS displays the correct memory information on the screen.
