Compaq Evo n610c Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the keyboard for the Compaq Evo n610c Notebook PC.
Minimum skill level
Tools required
Torx #8 (T8) screwdriver (preferably magnetized).
Parts required
The replacement part number will vary depending on the keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Keyboard with touchpad - Does not include point stick
440495-xx1 (Original)
No
101/102-key compatible keyboard - Industry standard full-width layout, isolated inverted-T cursor control keys, integrated numeric keypad, and hotkeys for power, volume, and brightness - 19.05 mm x 19.05 mm key pitch, 2.5 mm stroke
241428-xx1 (Original)
No
The part number will vary based on the country. Click here for a list of country specific spare part numbers.
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Remove the black T8-7 mm screw near the center of the base enclosure.
  3. Turn the notebook right side up.
  4. Open the display panel fully.
  5. Slide the four plastic locking tabs toward the keyboard to unlock the keyboard from the switch cover.
  6. Use a plastic flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
    Use care to prevent damaging the pointing stick and keyboard ribbon cables.
  7. For notebooks with a pointing stick, unlock the pointing stick ZIF connector and remove the pointing stick ribbon cable from the connector.
  8. Place the keyboard right side up on the top cover.
  9. Push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector.
  10. Remove the keyboard ribbon cable from the connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover.
  2. Insert the green keyboard ribbon cable stiffener into the top cover slot.
  3. Insert the keyboard ribbon cable into the ZIF connector.
  4. Push the locking bar toward the front of the notebook to lock the ZIF connector.
  5. Place the keyboard upside down on the top cover.
  6. For notebooks with a pointing stick, insert the pointing stick ribbon cable into the ZIF connector and lock the ZIF connector.
  7. Place the keyboard right side up on the top cover and toe the tabs on the bottom edge of the keyboard into the top cover.
  8. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the switch cover.
  9. Close the display panel and turn the notebook upside down.
  10. Replace the black T8-7 mm screw.
