HP Z200 Small Form Factor Workstation - Specifications
Physical specifications
Feature
Chassis dimensions (W x D x H)
  • Standard desktop orientation: 100 mm x 338 mm x 381 mm (3.95 in x 13.3 in x 15.0 in)
  • Optional small form factor tower orientation (excluding stand dimension): 338 mm x 100 mm x 381 mm (13.3 in x 3.95 in x 15.0 in)
  • System weight1: 7.6 kg (16.72 lbs)
  • Shipping weight1: 8.1 kg (17.86 lbs)
  • Max supported weight (desktop orientation): 35 kg (77 lb)
Exact weights depend upon configuration.
1: Configured with one hard drive, one optical drive and one NVIDIA Quadro NVS 295 low profile graphics card.
Environmental specifications
Feature
Temperature
Operating: 5° to 35°C (40° to 95°F)
Non-operating: -40° to 60°C (-40° to 140°F)
Humidity
Operating: 8% to 85% RH, non-condensing
Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
Operating: 3,000 m (10,000 ft)
Non-operating: 9,100 m (30,000 ft)
Dynamic (new)
Shock
  • Operating:
    1/2-sine: 40 g, 2-3 ms
  • Non-operating:
    1/2-sine: 2-3 ms (~100 g), 160 cm/s
    square: 20 g, 422 cm/s
Vibration
  • Operating random: 0.5 g (RMS), 5-300 Hz
  • Non-operating random: 2.0 g (RMS), 10-500 Hz
Cooling
Above 1524 m (5,000 ft) altitude, maximum operating temperature is derated by 1°C (1.8°F) per 305 m (1,000 ft) elevation increase.
Technical specifications
Feature
System board form factor
BTX 21.2 mm x 26.7 mm
Intel PCH 3450
Super I/O controller
SMSC SCH5327, Rev B
Processor socket
Single LGA 1156
Processors
Quad-Core Intel Xeon Processor 3400 Series with Intel Nehalem Architecture:
  • Intel Xeon Processor X3430 2.40 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3440 2.53 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3450 2.66 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3460 2.80 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3470 2.93 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
Dual-Core Intel Clarkdale Processors:
  • Intel Pentium Processor G6950 2.8 GHz, 3MB cache, 1066 MHz memory, Dual-Core
  • Intel Core Processor i3-530 2.93 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT
  • Intel Core Processor i3-540 3.06 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT
  • Intel Core Processor i5-650 3.2 GHz, 4MB cache, 1333 MHz memory, Dual-Core, Turbo
  • Intel Core Processor i5-660 3.33 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT, Turbo
  • Intel Core Processor i5-670 3.46 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT, Turbo
CPU bus speed
DMI
Memory expansion slots
4 DDR3 memory slots
Maximum memory
16GB
Memory
Custom to Order (CTO):
  • PC3-10600 DDR3-1333 ECC Unbuffered DIMMs CTO
    • 16GB (4 x 4GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 8GB (2 x 4GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 8GB (4 x 2GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 4GB (2 x 2GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 3GB (3 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 2GB (2 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 1GB (1 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    Two channels of DDR3 memory are supported. To realize full performance at least one DIMM must be inserted into each channel. The CPUs determine the speed at which the memory is clocked. If a 1066 MHz capable CPU is used in the system, the maximum speed the memory will run at is 1066 MHz regardless of the specified speed of the memory.
After Market Options (AMO):
  • PC3-10600 DDR3-1333 ECC Unbuffered DIMMs AMO
    • 4GB (1 x 4GB) DDR3-1333 ECC Unbuffered RAM
    • 2GB (1 x 2GB) DDR3-1333 ECC Unbuffered RAM
    Only unbuffered DDR3 DIMMs are supported.
Hard drives
  • 160GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 160GB SATA 10000 RPM SFF in 3.5-inch Frame HDD
  • 250GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 300GB SATA 10000 RPM SFF in 3.5-inch Frame HDD
  • 320GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 500GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 1000GB (1TB) SATA 7200 RPM 3 Gb/s 3.5-inch HDD
Optical and removable storage
  • HP 16X DVD-ROM SATA Drive
  • HP 16X DVD+-RW SuperMulti SATA Drive
  • HP 22-in-1 Media Card Reader Kit
  • HP Blu-ray Writer
  • HP 22-in-1 3.5 JackBlack Media Card Reader with 1394a
Controller cards
HP FireWire/IEEE 1394a PCI Card
Graphics
  • Intel HD Graphics
Professional 2D
  • NVIDIA Quadro NVS 295 256MB PCIe Graphics Card
Entry 3D
  • NVIDIA Quadro FX 380 LP 512MB PCIe Graphics Card
Power supply
240 W wide-ranging, active Power Factor Correction, 89% Efficient
Multimedia and audio devices
  • HP Thin USB Powered Speakers
  • Integrated Intel/Realtek HD ALC261 Audio
Racking and physical security
  • Security cable with Kensington Lock
  • HP Solenoid Hood Lock and Hood Sensor
Networking and communications
Broadcom (5761) NetXtreme Gigabit Ethernet Plus NIC
  • Connector: RJ-45
  • Controller: Broadcom 5761 PCI-Express LAN Controller
  • Memory: 8 MB NVRAM serial Flash
  • Data Rates Supported: 10/100/1000 Mb/s
  • Compliance: IEEE 802.1P, 802.1Q, 802.2, 802.3, 802.3AB, 802.3u, and 802.3x
Intel Gigabit CT Desktop NIC
  • Connector: RJ-45
  • Controller: Intel WG82574L Gigabit Ethernet Controller
  • Memory: Integrated Dual 48K configurable transmit receive FIFO Buffers
  • Compliance: IEEE 802.1P, 802,1Q, 802.2, 802.3, 802.3AB and 802.3u compliant, 802.3x flow control
Other hardware
Monitors
  • HP ZR24w 24-inch S-IPS LCD Monitor
  • HP ZR22w 21.5-inch S-IPS LCD Monitor
  • HP LP3065 30-inch Widescreen LCD Monitor
  • HP LP2475w 24-inch Widescreen LCD Monitor
  • HP LP2275w 22-inch Widescreen LCD Monitor
  • HP DreamColor LP2480zx Professional Display
  • HP LP1965 19-inch LCD Monitor
  • HP LP2065 20-inch LCD Monitor
Screen size is measured diagonally.
Input devices
  • HP USB Laser Mouse
  • HP SpaceExplorer 3D USB Controller
  • HP USB 2-Button Optical Scroll Mouse
  • HP USB Standard Keyboard
  • HP PS/2 Optical Scroll Mouse
  • HP PS/2 Standard Keyboard
  • HP USB Optical 3-Button Mouse
  • HP USB Smart Card Keyboard
  • HP 2.4 GHz Wireless Keyboard and Mouse
Backup devices
For a listing of compatible DAT tape drives, LTO tape drives, and RDX Removable Disk Backup System offerings, please follow one of the following two links:
Miscellaneous
  • HP Power Cord Kit
  • HP Workstation Mouse Pad
  • HP Serial Port Adapter
  • HP ENERGY STAR 5.0 Enabled Configuration
  • HP Parallel Port Adapter Kit
Country: Flag Bulgaria
