HP Compaq nx7000 Notebook PC - Removing and Replacing the Thermal Pad
This document is provided to assist in removing and replacing the thermal pad for the HP Compaq nx7000 Notebook PC.
Minimum skill level
The End-User must possess extensive product-specific knowledge and technical skill on how to service the system, and be familiar with the operating system.
Tools required
  • Small, Phillips-head P0 screwdrivers
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
  • Alcohol and a soft cloth or alcohol swabs
  • Tweezers
Parts required
The replacement part number will vary depending on the thermal pad that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Thermal pad assembly
337001-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the thermal pad, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Thermal pad from the menu on the upper left hand side of the screen.
Click here to view the thermal pad removal video (right-click on the link to open in a new window/tab).
Thermal pad removal
  2.   note:
    1. The thermal pad should be replaced every time the heat sink is removed.
    2. A scraper may be necessary to completely remove the thermal pad.
    Use tweezers to peel the thermal pad off of the heat sink.
  3. Use alcohol and a soft cloth or an alcohol swab to clean all remaining thermal pad residue off of the heat sink and processor.
Thermal pad replacement
  1. Remove a new thermal pad from the backing sheet.
  2. Position the new thermal pad so that it covers the heat sink surface that comes in contact with the processor.
  3. To adhere the new thermal pad to the heat sink, use the backing paper to carefully apply pressure.
