HP Compaq nx7000 Notebook PC - Removing and Replacing the Display Panel Cable
This document is provided to assist in removing and replacing the display panel cable for the HP Compaq nx7000 Notebook PC.
Tools required
  • Small, Phillips-head P0 screwdrivers
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the display panel cable that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Cable kit - Includes speaker cover cable, modem cable, Bluetooth cable, and the Secure Digital (SD) card slot I/O board cable
336973-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the display panel cable, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Display panel cable from the menu on the upper left hand side of the screen.
Click here to view the display panel cable removal video (right-click on the link to open in a new window/tab).
Display panel cable removal
  2. Remove the four 3 mm P0 Phillips-head screws that secure the sides of the LCD panel to the display panel.
  3. Remove the four 5 mm P0 Phillips-head screws that secure the bottom of the LCD panel to the display panel.
  4. Lift and remove the LCD panel from the display panel.
  5. Place the LCD panel face down.
  6. Remove the tape that secures the display panel cable to the LCD panel.
  7. Disconnect the display panel cable from the LCD panel and remove.
Display panel cable replacement
  1. Reconnect the display panel cable to the LCD panel.
  2. Re-tape the display panel cable to the LCD panel.
  3. Turn the LCD panel face up and place it into the display panel.
  4. Replace the four 5 mm P0 Phillips-head screws that secure the bottom of the LCD panel to the display panel.
  5. Replace the four 3 mm P0 Phillips-head screws that secure the sides of the LCD panel to the display panel.
